clarify oneapi::mkl::sparse::omatcopy
sycl-developer
The function "converts a sparse matrix in CSR format (that is defined by the three arrays csrVal, csrRowPtr, and csrColInd) into a sparse matrix in CSC format (that is defined by arrays cscVal, cscRowInd, and cscColPtr). The resulting matrix can also be seen as the transpose of the original sparse matrix. Notice that this routine can also be used to convert a matrix in CSC format into a matrix in CSR format."  Is that right ? Thanks
AryanK_Intel
>> Yes, your understanding is correct.
The resulting matrix might be seen as the transpose of the original sparse matrix but this routine can't be used to convert a matrix in CSC format into a matrix in CSR format.
Beacuse the CSR matrix must have a monotonically increasing row index and currently, the only supported matrix format for <sparse_matrix_type> is the csr format.
Please refer the below links for more details:
https://www.intel.com/content/www/us/en/docs/onemkl/developer-reference-dpcpp/2023-2/oneapi-mkl-sparse-omatcopy.html
https://www.intel.com/content/www/us/en/docs/onemkl/developer-reference-c/2023-1/sparse-blas-csr-matrix-storage-format.html
Sri Raj Aryan.K
AryanK_Intel
A gentle reminder:
Has the information provided helped? Could you please get back to us if you have any other queries.
Sri Raj Aryan.K
AryanK_Intel
Hi ,
We haven't heard back from you. Could you please provide us with an update on your issue?
Thanks & Regards,
Sri Raj Aryan.K
