cluster_sparse_solver computes wrong solution
asd__asdqwe
I'm trying to use cluster_sparse_solver and solve a system in-place (iparm(6) = 1), with a distributed format (iparm(40) = 1). I adapted the example cl_solver_unsym_distr_c.c as you can see attached, and at runtime, on two MPI processes, I get the following output:
$ icpc -V
Intel(R) C++ Intel(R) 64 Compiler XE for applications running on Intel(R) 64, Version 15.0.1.133 Build 20141023
$ mpicc -cc=icc cl_solver_unsym_distr_c.c -lmkl_intel_thread -lmkl_core -lmkl_intel_lp64 -liomp5
$ mpirun -np 2 ./a.out
The solution out-of-place of the system is:
 on zero process x [0] =  0.149579       rhs [0] =  1.000000
 on zero process x [1] =  0.259831       rhs [1] =  1.000000
 on zero process x [2] = -0.370084       rhs [2] =  0.250000
 on zero process x [3] =  0.011236       rhs [3] =  1.000000
 on zero process x [4] =  0.415730       rhs [4] =  1.000000
Solving system in-place...
The solution in-place of the system is:
 on zero process x [3] =  1.000000
 on zero process x [4] =  1.000000
Can you reproduce this behavior ? The solution in-place is obviously wrong. Do you see how to fix that ? Thank you in advance.
Alexander_K_Intel2
Everything is correct, current version of Direct Sparse Solver for Clusters doesn't support combination of in-place (iparm(6) = 1) solution with distributed rhs and non-distributed solution vector (iparm(40)=1)
Alex
