computation time for 1024 pt complex FFT using MKL_FFT
rakesh
HI,
i have been evaluating FFT of MKL.while computing , FFT takes approx. 1 milisecond which is too high.
i'm using following part of code to measure time of fft computation.
s_initial=dsecnd();
fft computation;
s_elapsed=dsecnd()-s_initial;
printf("time in milisec=%f",s_elapsed*1000);
can any one tell me how to reduce time compuation time gurther.
i'm using intel processor.
Dmitry_B_Intel
This size FFT *computation* should take on the order of 10 microseconds. If timing includes the planning/commit time, then it will take longer, of course. Yet, 1 millisecond is very large. Dima
TimP
Timing such short intervals is impractical in Fortran on Windows. It's possible but ugly to interface with QueryPerformanceCounter (less ugly, call a C function invoking __rdtsc()). Under linux, I would suggest system_clock with integer(8) arguments.
Gennady_F_Intel
actually dsecnd() is wrapper for __rdtsc, therefore customer can use this timing routine even for this short intervals too.
rakesh
Thanks a lot .
rakesh
Hi, earlier i was calculating for only one iteration once i increased the no of iteration from one to 100 the calculation time reduced in the order of microsecond. now i get computation time around 0.02 ms(approx) for 1024 pt complex FFT.
Bernard
Valued Contributor I
While measuring time needed to complete 4096 sine values FFT routine I got ~121245 nanoseconds i.e 121 microseconds.Compiler intrinsic __rdtsc() was used and averaged.I hope that time interval needed to complete the FFT calculation was not influenced by the rdtsc latency which is thousand times slower.
