7234 Discussions
dgbsv() and "double* ab" argument, banded matrix format in C++
ozarbit
Hello, I am now playing with the banded matrix form for the Ax=B system anddgbsv() driver function.
I have a 5 band matrix ( 2 upper + diagonal + 2lower )
I coulnd't find in the MKL manual the format expected, in C/C++, for banded matrices,
I couldn't even find the signature explicitely in the manual, but i found it in ...
the double* ab points to the banded matrix.
double ab[] = {
0., 0., 5., 6. , 7. , 8. , 9. , 10., 11., // most upper diagonal
0., 5., 6., 7. , 8. , 9. , 10., 11., 12., // upper diagonal
5., 6., 7., 8. , 9. , 10., 11., 12., 13., // diagonal
6., 7., 8., 9. , 10., 11., 12., 13., 0. , // lower diagonal
7., 8., 9., 10., 11., 12., 13., 0. , 0. }; // lowest diagonal
double b[] =
{ 0., 1., 2., 3., 4., 5., 6., 7. , 8. };
const MKL_INT n =sizeof(b)/sizeof(double);
MKL_INT nn = n;
MKL_INT nrhs =1;
MKL_INT kl =2;
MKL_INT ku =2;
MKL_INT ldab =5;
MKL_INT info;
MKL_INT ipiv;
LARGE_INTEGER t0, t1;
dgbsv( &nn, &kl, &ku, &nrhs, ab, &ldab, ipiv, b, &nn, &info );
the error is
MKL ERROR: Parameter 6 was incorrect on entry to DGBSV
is Parameter 6 ldab (value 5) ?or is it ipiv?
regards,
TimP
Quoting - ozarbit
MKL_INT nn = n;
MKL_INT nrhs =1;
MKL_INT kl =2;
MKL_INT ku =2;
MKL_INT ldab =5;
MKL_INT info;
MKL_INT ipiv;
the error is
I suggest referring to the reference source http://www.netlib.no/netlib/lapack/double/dgbsv.f
LDAB    (input) INTEGER
* The leading dimension of the array AB. LDAB >= 2*KL+KU+1.
so you have violated this documented constraint.
ozarbit
Quoting - tim18
Hello, I fixed the value of LDAB.
However the function call crashes now.
I am very unsure about the ab argument
From the documentation
"Band storage: an m-by-n band matrix with kl sub-diagonals and ku superdiagonals is stored compactly in a two-dimensional array ab with kl+ku+1 rows and n columns. Columns of the matrix are stored in the corresponding columns of the array, and diagonals of the matrix are stored in rows of the array."
The compact storage is then a 5 rows 9 columns in my case.
However, the C function signature expects a double*.
What should the ab array layout be? I looked at netlib.no re any remarks for the C layout w/o success.
regards,
TimP
Quoting - ozarbit
regards,
No, it seems unlikely anyone has posted a C example of the usage. As you are probably aware, the C view of a 2d Fortran array is a 1d array which runs by columns of the Fortran array. By my reading of the diagram in the source code, it begins with the first column, the first 3 elements of which are "unused," then runs down the second column, and so forth. ending with the last column, with 2 "unused" elements at the end, in that example. This agrees with my reading of your text quote.
You probably should avoid attempting to interpret the resulting LU decomposition, if at all possible.
While this organization is backwards from the usage I remember in IMSL from years ago, it is better for data locality.
ozarbit
Quoting - tim18
I tested on Excel. That initial matrix was singular, I changed it to the following problem.
| 10 5 5 0 0 0 0 0 0 |
| 1 5 56 6 0 0 0 0 0 |
| 7 7 7 7 7 0 0 0 0 |
| 0 8 8 8 8 8 0 0 0 |
| 0 0 9 9 10 9 9 0 0 | = A
| 0 0 0 10 10 10 10 10 0 |
| 0 0 0 0 11 11 11 11 11 |
| 0 0 0 0 0 12 12 12 12 |
| 0 0 0 0 0 0 13 13 13 |
This a band matrix, 2 upper diagonals and 2 lower diagonals. This actually has determinant !=0 and
A*x = b
where
b = 0
1
2
3
4
5
6
7
8
has a solution.
Now, the signature in C of the driver function for Ax=b where A is banded is
dgbsv( MKL_INT *n, MKL_INT *kl, MKL_INT *ku, MKL_INT *nrhs, double *ab, MKL_INT *ldab, MKL_INT *ipiv, double *b, MKL_INT *ldb, MKL_INT *info );
MKL_INT n = 9;
MKL_INT kl = 2;
MKL_INT ku = 2;
MKL_INT nrhs =1;
MKL_INT ldab = 2*kl + ku +1 = 7;
MKL_INT ipiv;
MKL_INT ldb = n;
MKL_INT info;
In fortran, the compact storage of A in ab would be:
x x 5 6 7 8 9 10 11
x 5 56 7 8 9 10 11 12
10 5 7 8 9 10 11 12 13
1 7 8 9 10 11 12 13 x
7 8 9 10 11 12 13 x x
But, from the docs, "The second dimension of ab must be at least max(1, n). ", i.e. 9
"The first dimension of the array ab. (ldab 2kl + ku +1)", i.e. 7
The 1stdimis the number of rows in Fortran, so 7 rows
The 2nd dim is the number of columns in Fortran so 9 columns
So i change the compact storage to include 2 additional rows (probably required for the LU decomposition)
x x 5 6 7 8 9 10 11
x x x x x x x x x
x x x x x x x x x
Then I transform this 2d array to 1d array in C, based on your reply" which runs by columns of the Fortran array",
to give me
double ab[] = {
0. , 0. , 10., 1. , 7. , 0., 0.,
0. , 5. , 5. , 7. , 8. , 0., 0.,
5. , 56., 7. , 8. , 9. , 0., 0.,
6. , 7. , 8. , 9. , 10., 0., 0.,
7. , 8. , 9. , 10., 11., 0., 0.,
8. , 9. , 10., 11., 12., 0., 0.,
9. , 10., 11., 12., 13., 0., 0.,
10., 11., 12., 13., 0. , 0., 0.,
11., 12., 13., 0. , 0. , 0., 0.
and
double b[] = { 0., 1., 2., 3., 4., 5., 6., 7. , 8. };
callingdgbsv( &nn, &kl, &ku, &nrhs, ab, &ldab, ipiv, b, &nn, &info );
returns info =8
which means U(8,8) is 0 according to docs, however matlab and excel concord in the solution.
I deduce that my transposition to the C array is wrong.
thank you for any advice,
best regards,
TimP
In the dgbsv source code listing comments, the expansion rows are shown above the entry data rows (preceding, in C), opposite to what you show here. I think your correspondence between Fortran and C array layout is OK.
ozarbit
Quoting - tim18
finally, that was it.... thanks very much.
I think the MKL manual should definitely describe the placement of the expansion rows.
thanks again
Michael_C_Intel4
Just locate the matrix differently:
double ab[] = {
0., 0., 0. , 0. , 10., 1. , 7. ,
0., 0., 0. , 5. , 5. , 7. , 8. ,
0., 0., 5. , 56., 7. , 8. , 9. ,
0., 0., 6. , 7. , 8. , 9. , 10.,
0., 0., 7. , 8. , 9. , 10., 11.,
0., 0., 8. , 9. , 10., 11., 12.,
0., 0., 9. , 10., 11., 12., 13.,
0., 0., 10., 11., 12., 13., 0. ,
0., 0., 11., 12., 13., 0. , 0.
Extra kl elements are added to the upper factor U during factorization, therefore the space should be left above the matrix, not below.
There's a description of the banded matrix arguments in Appendix B. Matrix Arguments of MKL manual mklman.pdf, you may refer to it.
Do you feel that the MKL documentation is ambiguous or not sufficient in this case?
Michael.
ozarbit
double ab[] = {
Michael.
Thanks Michael.
As a matter of a fact, the example in Appendix B Matrix arguments. The expansion rows are visible in the example. It is clear. I apologize.
The Fortan to C translation for arrays is also probably mentioned somewhere in the manual, but if it isn't, it may be useful to list as well. Thanks again,
regards,
