7298 Discussions
dgemm - Intel inspector: "uninitialized memory acces"
Guillaume_A_
New Contributor II
I launched an Memory Error Analysis with Intel Inspector on simple test of the dgemm function and i got this warning: "uninitialized memory access" located on the dgemm call.
Here is my test (really simple !) :
void dgemm_test()
  double *A,*B,*C;
  double alpha, beta;
  int m,i;
  m = 10;
  A = (double*)mkl_malloc((m*m)*sizeof(double),128);
  B = (double*)mkl_malloc((m*m)*sizeof(double),128);
  C = (double*)mkl_malloc((m*m)*sizeof(double),128);
  for(i=0; i<m*m; i++){
    A = (double)(rand() % (m*m)) / (double)(m*m);
    B = (double)(rand() % (m*m)) / (double)(m*m);
    C = 0.0;
  alpha = 1.0;
  beta = 0.0;
  cblas_dgemm(CblasRowMajor, CblasNoTrans, CblasNoTrans, m, m, m, alpha, A, m, B, m, beta, C, m);
  mkl_free(A);
  mkl_free(B);
  mkl_free(C);
Each buffer seems to be initialized... Do I have to be worried about this warning ? Is it an expected behavior ?
My configuration: Intel Inspector XE 2013.  MKL: 11.1.2 (32bit mode). CPU: Xeon E5-1620. OS: W7 64bit (SP1).
Thanks in advance for your help !
Zhang_Z_Intel
This is a known problem of Intel Inspector. It reports false alarms for some MKL routines.
mecej4
The problem with partial reports such as yours is that they cannot be verified.
Using the current versions of Intel C (15.0) and MKL (11.2) with the older Inspector 2013, I added a few lines of code to make a complete example as shown below. Note that I have suppressed initialization of C, which should be OK when alpha = 0. I see no reports of uninitialized variables with Inspector XE. However, when I change the value of alpha to a nonzero value, I do get detection of uninitialized variables. Reactivation of the initialization of C made the error go away. All these findings agree with what one expects.
#include <stdio.h>
#include <mkl.h>
void dgemm_test()
  double *A,*B,*C;
  double alpha, beta;
  int m,i;
  m = 10;
//    C = 0.0;
  alpha = 0.0;
  beta  = 1.0;
  mkl_free(A);
  mkl_free(B);
  mkl_free(C);
main(){
dgemm_test();
Zhang_Z_Intel
Gennady_F_Intel
btw, the latest version of Inspector ( Intel(R) Inspector XE 2015) doesn't report such sort of problem.
