7303 Discussions
dgemv - Invalid memory access for small dynamically allocated arrays
Sebastien_B_1
I do a blas matrix/vector product with this simple code in VS2013:
#include "mkl.h"
#include <stdio.h>
int main(){
const int M = 2;
const int N = 3;
double *x = new double[N];
double *A = new double[M*N];
double *b = new double[M];
for (int i = 0; i < M; i++){
    b[i] = 0.0; //Not necessary but anyway...
    for (int j = 0; j < N; j++){
        A[j * M + i] = i + j * 2;
    x[j] = j*j;
const int incr = 1;
const double alpha = 1.0;
const double beta = 0.0;
const char no = 'N';
dgemv(&no, &M, &N, &alpha, A, &M, x, &incr, &beta, b, &incr );
printf("b = [%e %e]'\n",b[0],b[1]);
delete[] x;
delete[] A;
delete[] b;
While the displayed result is as expected ([18, 23]), Intel Inspector finds one invalid memory accessand 2 invalid partial memory access when calling dgemv. The invalid memory access and one invalid partial memory access are related to memory allocated corresponding to the vector b. The second invalid partial memory access is related with the memory allocated for A. I do not get any error if I use a static array.
It also happens with other MKL functions, such as dgesv or with cblas_dgemv. The error appears only on small-size arrays, probably because MKL is trying to access memory in large chunks for efficiency. After more testing, I concluded that M needs to be at least 20 in order to not get an error. N can be any positive number.
I use Intel Inspector XE 2016 and intel C++ Compiler 16.0 with MKL 11.3 update 4, run sequential.
Is it safe anyway to use MKL on small matrices?
This is a question I originally posted on stackoverflow, but it looks like it may be a bug:
http://stackoverflow.com/questions/40303672/mkl-dgemv-invalid-memory-access-for-dynamically-allocated-arrays
Gennady_F_Intel
yes, it save to use mkl for an arbitrary matrixes. I do believe this is some issue with Inspector. For example, Inspector reports , memory leaks in your case when dgemv is commented and mkl_malloc/mkl_free is used.
