7302 Discussions
dyld[10296]: Library not loaded: @rpath/libmkl_intel_lp64.1.dylib
user001
I downloaded the Intel oneAPI Basic Toolkit and the HPC Toolkit on my Mac (Apple M2), and set the environment variables. When I try to run the program form my tutor(his also ueses intel oneAPI on Mac), I get the following error:
dyld[10296]: Library not loaded: @rpath/libmkl_intel_lp64.1.dylib.
At first I thought there was a problem connecting the dynamic library, but when I go to the lib directory, I find that there doesn't seem to be a file named libmkl_intel_lp64.1.dylib? I tried to install repeatedly and it didn't work either.
cd /opt/intel/oneapi/mkl/2023.0.0/lib/
The dynamic libraries that the program needs to link are as follows:
@rpath/libmkl_intel_lp64.1.dylib (compatibility version 0.0.0, current version 0.0.0)
@rpath/libmkl_intel_thread.1.dylib (compatibility version 0.0.0, current version 0.0.0)
@rpath/libmkl_core.1.dylib (compatibility version 0.0.0, current version 0.0.0)
@rpath/libiomp5.dylib (compatibility version 5.0.0, current version 5.0.0)
/usr/lib/libSystem.B.dylib (compatibility version 1.0.0, current version 1311.100.3)
I wonder if I really don't have libmkl_intel_lp64.1.dylib in my mkl library, or is the project my tutor gave me too old and needs to be updated?(the project works fine on my mentor's mac, but I don't know what version of his intel oneapi is)
ShanmukhS_Intel
We are working on your issue. We will get back to you soon with an update.
Shanmukh.SS
ShanmukhS_Intel
We are working on your issue internally. We will get back to you soon with an update. Regrets for the delay in response.
Shanmukh.SS
ShanmukhS_Intel
Could you please get back to us with a sample reproducer? as it help us reproduce the issue at our end and help you further?
Besides this, you could try creating a symbolic link as below and get back to us if the issue persists.
ln -s libmkl_intel_lp64.2.dylib libmkl_intel_lp64.1.dylib
Shanmukh.SS
user001
Your method worked very well, thank you very much! ! 0.0
ShanmukhS_Intel
A gentle reminder:
Has the information provided helped? Could you please get back to us with the earlier-mentioned details? It helps us triage the issue and help you further.
Shanmukh.SS
ShanmukhS_Intel
We assume that your issue is resolved. If you need any additional information, please post a new question as this thread will no longer be monitored by Intel.
Shanmukh.SS
user001
I'm using version 2021 of inter oneAPI, which has the mkl library containing libmkl_intel_lp64.1.dylib, but not version 2023.0.0, and I've used the above method without success. Since I didn't write the code, I only have the executable, so it looks like I have to use the old version of inter oneAPI.
But,the new version of the library should not contain all the content of the old library?
