7298 Discussions
access to oneMKL on host from inside container running rocky
cb4letni
Our campus cluster has 2 partitions of nodes running CentOS versions 6 and 7, respectively, the latter of which provide OS support for Singularity v3.9.0. Q. With the appropriate path bindings in SINGULARITY_BINDPATH, can we install and run oneMKL from within a container image running Rocky Linux 9.2?
Best,
CB
cb4letni
Also, each compute node is still hosting dual Xeon Phi 7120P co-processors (but no GPU's). In addition, I'd like to know if oneMKL still has support for those Xeon Phi co-processors. Thank you.
RahulC_Intel
Hi Carl, please refer to the link: https://www.intel.com/content/www/us/en/developer/articles/system-requirements/oneapi-math-kernel-library-system-requirements.html and check the supported Operating System for IIntel® oneAPI Math Kernel Library.
RahulC_Intel
Hi Carl, unfortunately we were unable to hear back from you.
If you have any further query, please post a new question as this thread will no longer be monitored by Intel®.
