7298 Discussions
fatal error U1073: dont know how to make 'mkl_blas.mod'
Anthony_Apicella
I am interested to build the blas95 and lapack95 interfaces on an em64t box for both 32 bit and 64 bit applications. I have copied the MKLInterfaces directory to my desktop and tried to build the 64 bit version of the interface with the following:
REM Configure to use 64 bit compiler
C:Program Files (x86)IntelCompilerFortran10.1.021em64tinifortvars.bat
REM Now build
nmake libem64t
and then it compiles all the sources and then
ifort /c /MT /Zl /Foobj sourceztrsv.f90
Intel Visual Fortran Compiler for applications running on Intel 64, Versio
n 10.1 Build 20080312 Package ID: w_fc_p_10.1.021
Copyright (C) 1985-2008 Intel Corporation. All rights reserved.
del /f/q objmkl_blas_protos.obj
lib -out:objmkl_blas95.lib obj*.obj
Microsoft Library Manager Version 9.00.21022.08
Copyright (C) Microsoft Corporation. All rights reserved.
del /f/q *.mod *.obj
del /f/q obj*.obj
NMAKE : fatal error U1073: don't know how to make 'mkl_blas.mod'
Stop.
NMAKE : fatal error U1077: '"C:Program Files (x86)Microsoft Visual Studio 9.0
VCBIN make.EXE"' : return code '0x2'
Stop.
Stop.
Thank you
Vladimir_Koldakov__I
New Contributor III
Hello, aapicella,
The next files and directories are required to build blas95 and lapack95 libraries:
includemkl_blas.f90
includemkl_lapack.f90
interfaceslas95source*.f90
interfaceslas95makefile
interfaceslas95las95.lst
interfaceslapack95lapack95.lst
interfaceslapack95source*.f90
interfaceslapack95makefile
em64tlib
Libraries and .mod files will be built in the em64tlib directory.
I believe, only MKLincludemkl_blas.f90 filehas not beencopied.
-Vladimir
