7302 Discussions
MKL_DSS_OOC_VARIABLE - anyone got this to work?
AndrewC
New Contributor III
I have recently moved to MKL 10.0 Update 3 and was hoping that the OOC of Pardiso/DSS might actually work....
My well-tested solver works perfectly fine without MKL_DSS_OOC_VARIABLE in the options, but when I add that to the options passed to dss_create, the dss solver crashes inside dss_factor_real on a medium-sized problem ( not that large!)
Andrew
Tyler_T_Intel
Andrew - we have successfully tested and have seen other developers have success with our out-of-core PARDISO. Might you be able to submit an issue in in Intel Premier Support with additional information to help reproduce the problem.
--tyler
AndrewC
New Contributor III
I will submit a premier support ticket. What would be really useful for support would be a trace mode, where the calls to mkl and inputs to 'selected' mkl functions are dumped to a file-rather than the user having to painfully extract test data from a running program and build a test application to show the problem.
AndrewC
New Contributor III
FYI, I submitted a premier support ticket with a reproducible example and it has been confirmed as a bug in the OOC of DSS/PARDISO.
Todd_R_Intel
Just a note that this bug has been isolated and a fix is targeted for an update release.
-Todd
