7300 Discussions
MKL 9.1 Linking a shared lib that uses mkl_solver.a on LINUX em64t
AndrewC
New Contributor III
I think something slipped through the QA cracks.
I cannot link my shared library with the mkl solver lib on Linux em64t. This used to work fine under MKL 9.0.
libmkl_solver.a is a static library, but that should not prevent it being linked as part of a shared library. Looks like someone forgot to compile it fPIC.
ld: /opt/intel/mkl/9.1/lib/em64t/libmkl_solver.a(util.o): relocation R_X86_64_32 against `a local symbol' can not be used when making a shared object; recompile with -fPIC
/opt/intel/mkl/9.1/lib/em64t/libmkl_solver.a: could not read symbols: Bad value
Intel_C_Intel
This sounds like an error and should be submitted to your Premier account at http://premier.intel.com. If you do that this issue will get logged into the system, get thoroughly checked out, and tracked. I would appreciate your submitting this to start the evaluation and repair, if appropriate, process.
Bruce
AndrewC
New Contributor III
I have submitted a problem report
Intel_C_Intel
Thanks. I think is the best way for this issue.
Bruce
Tony_Garratt
We are also seeing a very similar problem on linux 64bit but we are using MKL 10.0.012 - which presumably means this bug has still not been fixed?
Thank you!
Tony
ld: ../lib/libguide.a(kmp_csupport.o): relocation R_X86_64_32 can not be used when making a shared object; recompile with -fPIC
../lib/libguide.a: could not read symbols: Bad value
make: *** [../bin/libCK.so] Error 1
AndrewC
New Contributor III
The bug I saw was definitely fixed. You probably need to link to the shared library version of libguide.
Tony_Garratt
Thank you for the quick reply. We want to use static libraries to avoid having to ship re-distributables. Is there a way around this that doesnt involve shared libraries please?
Thank you
Tony
AndrewC
New Contributor III
The only work around I can think of if you absolutely do not want to ship libguide.so would be to ask Intel nicely to compile libguide.a with -fPIC. It does seem like an oversight on their part.
Todd_R_Intel
To address this bug the threading libraries were built with -fPIC in Update 3 which was made available in April.
-Todd
