7303 Discussions
fatal error: mkl.h: No such file or directory
Maraki
I have installed intel One base toolkit on windows and I am trying to compile  a c code in R desktop. I am facing the following issue:
> system("R CMD SHLIB example.c")
using C compiler: 'gcc.exe (GCC) 12.2.0'
gcc  -I"C:/PROGRA~1/R/R-43~1.1/include" -DNDEBUG     -I"c:/rtools43/x86_64-w64-mingw32.static.posix/include"     -O2 -Wall  -mfpmath=sse -msse2 -mstackrealign  -c example.c -o example.o
example.c:3:10: fatal error: mkl.h: No such file or directory
    3 | #include <mkl.h>
compilation terminated.
make: *** [C:/PROGRA~1/R/R-43~1.1/etc/x64/Makeconf:265: example.o] Error 1
I've read here instructions on utilizing R with Intel MKL, but those specific instructions are designed for Linux, and I don't have the expertise to modify the process as I'm not well-versed in Linux.
I have tried also the following but  with no luck
> system("R CMD SHLIB -I 'C:/Program Files (x86)/Intel/oneAPI/mkl/latest/include' example.c")
make: *** No rule to make target 'Files'.  Stop.
[1] 1
Thank you very much
Maraki
VarshaS_Intel
Could you please let us know the Intel MKL version you are using?
Also, could you please provide us with the complete steps you are following on the R desktop along with the sample reproducer code you are using?
Thanks & Regards,
Varsha
VarshaS_Intel
From this error, we can see that Intel MKL does not link properly. Also, from the compiler options provided by you, we did not see the option '-qmkl' so this might be causing an error.
Could you please try adding the flag and let us know if you still have any other issues?
Thanks & Regards,
Varsha
VarshaS_Intel
We have not heard back from you. Could you please provide us with an update on your issue?
Thanks & Regards,
Varsha
VarshaS_Intel
Thanks & Regards,
Varsha
