gamma function?
yjyincj
I am using intel MKL for linux version=10.2.2.025. I can not find gamma() in the VML special function lists. Any idea? Thanks.
ArturGuzik
Valued Contributor I
Quoting - yjyincj
You can't because there is not (I believe). You can get source code here.
A.
yjyincj
Quoting - ArturGuzik
A.
Gennady_F_Intel
Quoting - yjyincj
yjyincj,there are no such functionality into the current version.
I would recommend you submit the issue against MKL to Premier support( https://premier.intel.com/ )
--Gennady
yjyincj
--Gennady
I could not login premier.intel.com using my account yjyincj.
ArturGuzik
Quoting - yjyincj
I actually also would be happy to see it. I submitted the feature request. Number 571457.
A.
woleakande
Thanks so much for the link.You are very generous.
Me too has some codes but still in Fortran 95.
Am about to upgarde it to C/C++.
Shane_S_Intel
You will findthe"true" gamma functionin the Intel Compiler provided math library libimf.a(described here -http://software.intel.com/sites/products/documentation/hpc/compilerpro/en-us/cpp/lin/main_cls_lin.pdf).Its prototype is double tgamma(double). Note that both the lgamma() and gamma() functions return not gamma but the log gamma for historical reasons.
Francisco_Pe__241_u_
There is an article that maybe can help you.
Calling the lgamma function from the Intel Fortran Compiler. You can find it in the search bar.
