gemv for sparse, rectangular matrices?
damienhocking
Is there a recommended routine in the MKL that can do a GEMV with the transpose of a rectangular sparse matrix?  I know I can pad it to square but I'd prefer not to have to do that.  These sparse matrices could be large, 10 million+ nonzeroes and a million rows or columns.
Damien
Zhen_Z_Intel
mkl_?<format>gemv is designed for square, but mkl_?<format>mv can be used for rectangular matrix (m * k). Or, you could use Inspector-execute sparse function mkl_sparse_?_mv, normally would provide a better performance.
Zhen_Z_Intel
You provided BLAS level 2 function for sparse matrix. For sparse matrix, we normally use compressed data structure that Intel MKL supports CSR, CSC, COO, diagonal and skyline. You could learn more from developer reference about usage with different matrix structure& data compression format:
https://software.intel.com/en-us/node/520802
damienhocking
Yes, but the docs are all for a square m x m matrix.  I have rectangular matrices.
Zhen_Z_Intel
damienhocking
Thank you Fiona, that's exactly what I wanted.
