implementing fftw3 plan for complex numbers
ian_bellinfantie
I'm using the dp_plan_dft_1d.c type implementation from the MKL fftw3xc examples directory.
However, I'm having trouble assigning a value to the fft inputs. Below is the code extract and the debug info from vs2010.
in_y[0] = yy.real();
in_y[1] = yy.imag();
I get
- in_y 0x0000000000000000 double [2]*
[0] CXX0030: Error: expression cannot be evaluated
[1] CXX0030: Error: expression cannot be evaluated
- yy [131072](0.00000000000000000,0.00000000000000000,0.00000000000000000,0.00000000000000000,0.00000000000000000,0.00000000000000000,0.00000000000000000,0.00000000000000000,0.00000000000000000,0.00000000000000000,0.00000000000000000,0.00000000000000000,0.00000000000000000,0.00000000000000000,0.00000000000000000,0.00000000000000000,0.00000000000000000,0.00000000000000000,0.00000000000000000,0.00000000000000000,0.00000000000000000,0.00000000000000000,0.00000000000000000,0.00000000000000000,0.00000000000000000,0.00000000000000000,0.00000000000000000,0.00000000000000000,0.00000000000000000,0.00000000000000000,0.00000000000000000,0.00000000000000000,0.00000000000000000,0.00000000000000000,0.00000000000000000,0.00000000000000000,0.00000000000000000,0.00000000000000000,0.00000000000000000,0.00000000000000000,0.00000000000000000,0.00000000000000000,0.00000000000000000,0.00000000000000000,0.00000000000000000,0.00000000000000000,0.00000000000000000,0.00000000000000000,0.00000000000000000,0.00000000000000000,0.00000000000000000,0.00000000000000000,0.00000000000000000,0.00000000000000000,0.00000000000000000,0.00000000000000000,0.00000000000000000,0.00000000000000000,0.00000000000000000,0.00000000000000000,0.00000000000000000,0.00000000000000000,0.00000000000000000,0.00000000000000000,0.00000000000000000,0.00000000000000000,0.00000000000000000,0.00000000000000000,0.00000000000000000,0.00000000000000000,0.00000000000000000,0.00000000000000000,0.00000000000000000,-0.00000000000000000,-0.00000000000000000,-0.00000000000000000,-0.00000000000000000,-0.00000000000000000,-0.00000000000000000,-0.00000000000000000,-0.00000000000000000,-0.00000000000000000,-0.00000000000000000,-0.00000000000000000,-0.00000000000000000,-0.00000000000000000,-0.00000000000000000,-0.00000000000000000,-0.00000000000000000,-0.00000000000000000,-0.00000000000000000,-0.00000000000000000,-0.00000000000000000,-0.00000000000000000,-0.00000000000000000,-0.00000000000000000,-0.00000000000000000,-0.00000000000000000,-0.00000000000000000,-0.00000000000000000,...,...) std::vector<:COMPLEX>,std::allocator<:COMPLEX> > >
[size] 131072 long
[capacity] 131072 long
+ [0] 0.00000000000000000 std::complex
Can someone please advise where i am going wrong?
Ying_H_Intel
Hi ian,
Could you please provide a test case to show the problem?
we can't reproduce the problem with MSVC2010, win32 console application.i modify thefile to CPP file as complex isfrom C++. and do exact as yourassignments. The below the related code, Attached is the wholecpp file.
int N=131072;
/* Initialize array x with harmonic H */
static void init(fftw_complex *x, int N, int H)
std::complex *yy;
yy= new std::complex;
for (n = 0; n < N; n++)
std::complex tmp(0.1*n, 0.5*n);
yy=tmp;
x[0] = yy.real();
x[1] = yy.imag();
Ying
