inversion of sparse complex matrix
Vahid_Jalili
Is it possible to invert a sparse complex matrix with MKL using C?
I have foundcsytri( uplo, n, a, lda, ipiv, work, info ) in LAPACK, but I guess it is not supposed toworkwith sparse matrices and also in C.
Thanks for your help
Alexander_K_Intel2
You can use PARDISO with n rhs, where n is size of matrix. If you set rhs in next way:
rhs_i=1;
rhs_i=0 i<>j;
then solution vector will store inverse matrix.
With best regards,
Alexander Kalinkin
TimP
Needless to say, the inverse is no longer sparse, so inverting a sparse matrix is expensive in storage and time, and very inefficient if the aim is to solve a system of equations.
Vahid_Jalili
I want to have the result of multiplication of 3 complex matrices as: Y1*inv(Y2)*Y3
So, I don't want to solve a system. Y1 (mxn), Y2 (nxn) and Y3 (nxm) are very large and heavily sparse. Do you have any suggestion for me how to make it with MKL routines?
Vahid_Jalili
Alexander, thanks for your help.
Do you know if I can do this with DSS routines instead of PARDISO? Is it possible to define rhs as an I matrix in DSS routines?!
Alexander_K_Intel2
You can define many rhs in the same way that I described upper and use dss function dss_solve_complex. By the way Y=Y1*inv(Y2)*Y3 seems like Schur complimented. Are you really need to have this matrix or you need to multiply it on some vector only? Ive asked it because inverse of sparse matrix is dense and will calculate really long time. But if you need to multiply matrix Y on some vector only you can do it in next way:
x=Yr=Y1*inv(Y2)*Y3*r;
x1=Y3*r; //calculated by mkl_ccsrgemv
x2= inv(Y2)*x1; //x2 is solution of system Y2*x2=x1, calculated by PARDISO/DSS
x = Y1*x3 // calculated by mkl_ccsrgemv
With best regards,
Alexander Kalinkin
Dan4
Not necessarily! Of course solving an equation using inverting the coefficient matrix is not a good idea in general, no matter the matrix is sparse or dense or what format has been used, but inversion is really needed in for example electromagnetic analysis and/or graphical calculations. Besides, in many cases, the inversion of a non-singular sparse matrix will still be sparse. Using PARDISO seems to be the only reasonable way, but if the storage of your sparse matrix won't exceed the peak usage of the memory, so it may be better to simply store the data in dense format and invert it.
Good luck,
D.
Alexander_K_Intel2
HI,
I agree that inverse of sparse matrix could be sparse but PARDISO package doesnt take it into account. Briefly, PARDISO calculate each column of inverse matrix by setting rhs as correspondent column of unit matrix. So size of each column of inverse matrix is N and size of inverse matrix is NxN, where N is size of initial matrix. Hence the size of the matrix is equal to the size of a dense one even though the inverse matrix contains a lot of zeros.
With best regards,
Alexander Kalinkin
Dan4
That's true! That's why the output matrix has always been assumed to be dense. However, there are algorithms tailored for inverting sparse matrices that I didn't find in MKL, like Fast Inverse using Nested Dissection (FIND).
Dan
Gennady_F_Intel
that's also true. -:). there is no similar functionality into the current version.
