7302 Discussions
is FFTW wrapper call thread safe inside OpenMP region?
mohanmuthu
Good Day!
I am using the FFTW compatible wrapper for FFT and compiling the code with /Qmkl:sequential option. It works well in serial execution. The question I have is,
(A) if I do the same inside the OpenMP parallel region as mentioned below, is it thread safe?
Also,
(B) do I need to change the compiler option from /Qmkl:sequential to /Qmkl:parallel, or its not required since I am not going to use parallel threads within FFTW.
!$OMP PARALLEL DEFAULT(NONE) PRIVATE(plan, x, y) SHARED(n, FFTW_ESTIMATE)
!$OMP DO
    CALL sfftw_plan_dft_r2c_1d(plan, n, x, y, FFTW_ESTIMATE)
    CALL sfftw_execute_dft(plan, x, y)
    CALL sfftw_destroy_plan(plan)
!$OMP END DO
!$OMP PARALLEL
 Appreciate any help I can get on this topic.
Barbara_P_Intel
This is best answered by those on the MKL Forum. I'll move this thread there.
