7303 Discussions
is the implemented Trust Region method deterministic?
Gianluca_G_1
In this case results cannot change if initial condition and constraints are the same ...
this is what happen in our implementation.
Thank you
Gianluca
Ying_H_Intel
Hi Gianluca,
i write one email to you today, hope it disclose the inconsistent problem.
Theoretically , besides initial condition and constraints are the same,  the run-time executable order are same,  the implemented Trust Region method is deterministic.
Ying
Some discussion in MKL user guide about the floating-point computation and MKL implementation:
Intel® Math Kernel Library (Intel® MKL) offers functions and environment variables that help you obtain
Conditional Numerical Reproducibility (CNR) of floating-point results when calling the library functions from
your application. These new controls enable Intel MKL to run in a special mode, when functions return bitwise
reproducible floating-point results from run to run under the following conditions:
• Calls to Intel MKL occur in a single executable
• The number of computational threads used by the library does not change in the run
It is well known that for general single and double precision IEEE floating-point numbers, the associative
property does not always hold, meaning (a+b)+c may not equal a +(b+c). Let's consider a specific example.
In infinite precision arithmetic 2
-63 + 1 + -1 = 2-63
. If this same computation is done on a computer using
double precision floating-point numbers, a rounding error is introduced, and the order of operations becomes
important:
(2
-63 + 1) + (-1)
≃ 1 + (-1) = 0
versus
2
-63 + (1 + (-1))
≃ 2-63 + 0 = 2-63
This inconsistency in results due to order of operations is precisely what the new functionality addresses.
The application related factors that affect the order of floating-point operations within a single executable
program include selection of a code path based on run-time processor dispatching, alignment of data arrays,
variation in number of threads, threaded algorithms and internal floating-point control settings
. You can
control most of these factors by controlling the number of threads and floating-point settings and by taking
steps to align memory when it is allocated (see the Getting Reproducible Results with Intel
MKL knowledge
base article for details). However, run-time dispatching and certain threaded algorithms do not allow users to
make changes that can ensure the same order of operations from run to run.
Intel MKL does run-time processor dispatching in order to identify the appropriate internal code paths to
traverse for the Intel MKL functions called by the application. The code paths chosen may differ across a wide
range of Intel processors and Intel architecture compatible processors and may provide differing levels of
performance. For example, an Intel MKL function running on an Intel
® Pentium®
4 processor may run one
code path, while on the latest Intel
® Xeon®
processor it will run another code path. This happens because
each unique code path has been optimized to match the features available on the underlying processor. One
key way that the new features of a processor are exposed to the programmer is through the instruction set
architecture (ISA). Because of this, code branches in Intel MKL are designated by the latest ISA they use for
optimizations: from the Intel
® Streaming SIMD Extensions 2 (Intel® SSE2) to the Intel®
Advanced Vector
Extensions 2 (Intel
AVX2). The feature-based approach introduces a challenge: if any of the internal
floating-point operations are done in a different order or are re-associated, the computed results may differ.
Dispatching optimized code paths based on the capabilities of the processor on which the code is running is
central to the optimization approach used by Intel MKL. So it is natural that consistent results require some
performance trade-offs. If limited to a particular code path, performance of Intel MKL can in some
circumstances degrade by more than a half. To understand this, note that matrix-multiply performance
nearly doubled with the introduction of new processors supporting Intel AVX2 instructions. Even if the code
branch is not restricted, performance can degrade by 10-20% because the new functionality restricts
algorithms to maintain the order of operations.
Gianluca_G_1
ok Thank you, now it is clear.
BR
Gianluca
Ying_H_Intel
For developers, please see the summary post at
https://software.intel.com/en-us/forums/intel-math-kernel-library/topic/737444
Ying
