issue with MKL with visual studio
YusufThaer
Dear All,
until today, I had visual studio 2019 installed with Intel Parallel studio and all was fine. I decided to install the new Intel onAPI. I uninstalled Intel Parallel Studio at first, then downloaded the one API base and HPC toolkit. I installed the base first then installed the HPC. I am doing that for using it for FORTRAN
I tried running my old projects that use use MKL as parallel or even sequential. I cant run any project that use MKL, I am sure the libraries are there in the directly and the visual studio rebuild the project without error but when I try to run the project, it tells me
" The code execution cannot proceed because mkl_intel_thread.1.dll was not found. reinstalling the program may fix this problem " . I uninstalled the hpc kit then uninstall the base one api then reinstall them again but it didnt work.
RahulV_intel
Hi Yusuf,
Follow these steps to include the missing DLL path:
  • Open the project property pages (Alt + Enter)
  • Change the Configuration to Debug (On the top left corner)
  • On the left window, under the Configuration properties tab, click on Debugging.
  • Under the Action tab, click on the Environment field and add the following:
PATH=C:\Program Files (x86)\Intel\oneAPI\mkl\latest\redist\intel64;%PATH%
Save the changes and run your executable. Let us know if you face any issues.
Rahul
PrasanthD_intel
Hi Yusuf,
As this is issue is related to MKL, we are moving this thread to the MKL forum(Intel® oneAPI Math Kernel Library & Intel® Math Kernel Library - Intel Community) for better support.
Prasanth
RahulV_intel
The issue is reproducible in my environment as well. However, there is a workaround given in this thread below.
https://community.intel.com/t5/Intel-oneAPI-Math-Kernel-Library/VS-2019-Debugger-reports-missing-dll-and-does-not-start/m-p/1257511#M30918
Could you please try it out and let us know if you face any issues?
Rahul
YusufThaer
I will try it and I will give you a feedback.
thank you very much
YusufThaer
I tried it and it worked.
When I opened oneAPI command and write DEVENV, the visual studio starts and things work like charm.
but I couldnt add the path as I dont know how to add it
JohnNichols
Honored Contributor I
1. Download a program called file seek.
2. Do a search on the c: drive for mkl*.dll
3. This will tell you where the missing dll's are located
4. Copy the folder location as text from Windows explorer
5. Open the environment variables -- google it
6. Add the location to the path command
7. It should work until the problem is fixed in an update.
YusufThaer
I found the place where the missing dll exists. I copied the path from the explorer and added it in the environment in debugger but it didnt work.
RahulV_intel
Hi Yusuf,
Rahul
Ever
No longer working. I just installed the latest version yesterday 6/19/2023 and repaired it today.
My code uses MKL, it can compile and build as both Debug x64 and Debus x86, but when executed I get "mkl_sequential.2.dll was not found."
This code was working back in 2018.
What can I do?
RahulV_intel
Hi Yusuf,
Could you please confirm if the solution provided helps? Let me know if you face any issues.
Rahul
RahulV_intel
Thanks for accepting the solution. The missing DLL issue will be fixed in the next oneAPI update.
Rahul
RahulV_intel
The missing DLL issue has been fixed in the latest release of the oneAPI base toolkit 2021.2. So, I will go ahead and close this thread from my end. Intel will no longer monitor this thread. Further interactions on this thread will be considered community only.
Rahul
