issue with intel debugger
rakesh
i'm evaluating fft function of mkl library.
i'm running example code under dftc directory. and example code is real_1d_ccs_double_ex1.c
and support c files are dfti_example_status_print.c, dfti_example_support.c.
i don't see any error during compilation and building the project.
but when i go to debug mode. it comes out of debug mode with  following message "Native has exited with code1(0x1)".
i'm not able to see output.
Gennady_F_Intel
how exactly have you linked this example? is it 10.3 version? win32 or 64?
rakesh
i have linked wit win32 and i'm using mkl which is part of intel parallel studio 11
rakesh
Ying_H_Intel
Hi Rakesh, I assume you are working the project with Microsoft Visual studio, right?. the example need input file real_1d_ccs_double_ex1.d which is located in directory data. But you can simplify the code , for example in real_1d_ccs_double_ex1.c comment the line and insert n=5. // if(read_data_file_1d(argc, argv, &n)) return 1; n=5; Then ctrl+F5, you will see the correct output. Best Regards, Ying I att
