lapack95 errors
Vishnu
I am trying to use an eigenvalue routine through the lapack95 interface of the mkl. But I end up with this:
$ ifort Eigen.f90 -mkl
/opt/intel/compilers_and_libraries_2016.3.210/linux/mkl/include/lapack.f90(28): error #6218: This statement is positioned incorrectly and/or has syntax errors.
MODULE F95_PRECISION
/opt/intel/compilers_and_libraries_2016.3.210/linux/mkl/include/lapack.f90(31): error #6790: This is an invalid statement; an END [PROGRAM]  statement is required.
END MODULE F95_PRECISION
/opt/intel/compilers_and_libraries_2016.3.210/linux/mkl/include/lapack.f90(31): error #6785: This name does not match the unit name.   [F95_PRECISION]
Eigen.f90(86): error #6785: This name does not match the unit name.   [EIGEN]
END PROGRAM Eigen
Eigen.f90(23): warning #5427: Program may contain only one main entry routine
IMPLICIT NONE
compilation aborted for Eigen.f90 (code 1)
Also, in the program, I have:
PROGRAM Eigen
INCLUDE 'mkl.fi'
INCLUDE 'lapack.f90'
IMPLICIT NONE
Any idea what the trouble might be?
Dmitry_B_Intel
Hi Vishnu,
The lapack.f90 file is not supposed to be included inside a program/subroutine/function. Either compile it separately, and then 'use lapack95' inside your program, or put the include statement outside of the program, at file level (possibly replacing include with #include and preprocessing the file).
Dima
mecej4
Vishnu wrote:
So you're saying that I should stick to  the LP64 even while I require 64bit reals, as long as I do not require 64bit integers. Is that right?
Precisely. The 'L' and 'P' stand for 'longs' and 'pointers', respectively. Floats are not part of this story at all. See https://en.wikipedia.org/wiki/64-bit_computing#64-bit_data_models for details.
Vishnu
Thanks for that. I had no clue.
