lapack95 project build error
wilcox__nigel
I have installed the math kernal and compiled the lapack95 library as per the get started manual and added mkl_lapack95.lib to the additional dependancies in project>properties>linker>input but when I build I get unresolved externals for the lapack95 routines. If I use the F77 routine names then the linker is happy. what have I not done?
thanks
Nigel Wilcox
ArturGuzik
Valued Contributor I
Quoting - Nigel Wilcox
Nigel,
what's are those externals? all the libraries/interfaces are adjusted?
A.
wilcox__nigel
Quoting - ArturGuzik
Nigel,
A.
all the lapack routines that I am calling
pbstf
sbgst
sbtrd
steqr
thanks you help
Nigel
ArturGuzik
pbstf
sbgst
sbtrd
steqr
thanks you help
Nigel
Nigel,
did you change (adjust) number/type of arguments, I mean, between versions? (95 version has usually smaller number of arguments than F77 counterpart). If yes, please do show the exact error message and line(s) of code which calls the routines in question.
A.
wilcox__nigel
Nigel,
A.
This is the region of code, (I am just testing it out right now)
call Get_Bandwidth(K, MDOF, Kl, Ku_K)
allocate (ab_K(Ku_K+1,MDOF))
call BandPack2(K,0,Ku_K,MDOF,ab_K,1)
call Get_Bandwidth(M, MDOF, Kl, Ku_M)
allocate (ab_M(ku_M+1,MDOF))
call BandPack2(M,0,Ku_M,MDOF,ab_M,1)
call pbstf(ab_M)
call sbgst(ab_K, ab_M)
allocate (d(MDOF))
allocate (e(MDOF-1))
call sbtrd(ab_K,,d,e)
call steqr(d, e)
End
The link errors
BHA_Dynamics error LNK2019: unresolved external symbol _PBSTF referenced in function _EIGEN_SOLVE3
BHA_Dynamics error LNK2019: unresolved external symbol _SBGST referenced in function _EIGEN_SOLVE3
BHA_Dynamics error LNK2019: unresolved external symbol _SBTRD referenced in function _EIGEN_SOLVE3
BHA_Dynamics error LNK2019: unresolved external symbol _STEQR referenced in function _EIGEN_SOLVE3
BHA_Dynamics fatal error LNK1120: 4 unresolved externals
Thanks again
Nigel
ArturGuzik
Nigel,
linker can't find the libraries. What's your linking line? Do you have both mkl_lapack95.lib and mkl_core.lib there? (lapack95 gives you interfaces but you still need core.lib linked). Other possible reason: did you USE module (say, USE mkl95_LAPACK, ONLY: ...., ....) correctly?
A.
wilcox__nigel
Nigel,
A.
My link line was correct but I did not have aUSE statement.
That has sorted it now
many thanks for your help
Nigel
