7303 Discussions
linux redistributables that go with comp xe 2011.11.339 compiler suite
happyIntelCamper
where can I download the linux redistributables that match the comp xe suite version 2011.11.339
These would be the redistributables for mkl and ipp.
Gennady_F_Intel
if you have this suite installed, then you can copy Intel MKL and IPP dlls (for Widnows*) from directory redist\(ia32\intel64)  to your destination application folder. For Linux and Mac OS* shared objects, .so files are located in lib\(ia32/intel64) directory.
Check mklsupport.txt ippsupport.txt which are located in Composer directory \Documentation\ for more details.
