memory allocation
yoo__jungmin
I wrote a sample code to test mkl_malloc as below.
When I run this code, I encounted memory error.
Could somebody explain to me why this happened and how to slove this problem??
typedef struct _a_
	int *data;
	_a_()
		data = (int *)mkl_malloc(10 * sizeof(int), 32);
		for (int i = 0; i < 10; i++)
			data = i;
	~_a_()
		mkl_free(data);
}a_;
int main(void)
	a_ *b;
	b = (a_ *)mkl_malloc(10 * sizeof(a_), 32);
	std::cout << b[0].data[0] << std::endl;
	mkl_free(b);
	return 0;
Pamela_H_Intel
Jungmin,
I can't say for sure because I need to know what the error was and which line it refers to. You may be getting the error because you declared data as a pointer but are attempting to traverse it as if it were an array. If you tell me what the error is I can be more certain.
Pamela
