7303 Discussions
memory leakage using the MKL functions: vsldCorrNewTask1D, vsldCorrExec1D and vslCorrDeleteTask
nh_wulff
Hi MKL forum
Can anybody hel me:
I am using the following routine to calculate the correlation between the two arrays x and y:
int intel_corr(double *h, int inch, double *x, int incx, double *y, int incy, int nh, int nx, int ny){
int status;
VSLConvTaskPtr task;
vsldCorrNewTask1D(&task,VSL_CONV_MODE_AUTO,ny,nx,nh);
status = vsldCorrExec1D(task,y,incy,x,incx,h,inch);
vslCorrDeleteTask(&task);
return status;
}/* intel_corr */
The routine works perfectly and is indeed very fast (much faster than the Numerical Recipes routines).
However, it seems that the function hasa little memory leakage. It is quite small and I can actually live with it, but maybe you guys can tell me if I use the above MKL functions wrongly?
Best regards
Niels
Gennady_F_Intel
We had the similar problem in the previous version of MKL and it has been already fixed. The fix available in MKL 10.2.
What MKL version you are using?
--Gennady
nh_wulff
--Gennady
Hi Gennady
Thanks for the answer. I am using ver 9.0 so I gues I just have to upgrade!
Again thanks a lot and have a nice day
Niels
barragan_villanueva_
Valued Contributor I
Hi Niels,
Could you please sendus detailsabout sizes used by you (and small test-case) when memory leak was detected?
-- Victor
nh_wulff
Hi Niels,
-- Victor
nh_wulff
Hi Niels,
-- Victor
Hi Victor
I only saw your question today.
The code in the attached file should demonstrate the memory leak.
best
Niels
Quoting - nh_wulff
Hi Victor
best
Niels
Niels,
Thank you for the test case! BTW, did you try it with the latest MKL 10.2.2?
-- Victor
Niels,
Using valgrind 3.5.0 and MKL 10.2.2, I have on your test-case:
==20378== HEAP SUMMARY:
==20378== in use at exit: 0 bytes in 0 blocks
==20378== total heap usage: 0 allocs, 0 frees, 0 bytes allocated
==20378==
==20378== All heap blocks were freed -- no leaks are possible
So, please upgrade your MKL.
-- Victor
nh_wulff
Niels,
-- Victor
No, I have not got that version yet (I think that I will look into that sometime next year).
best
Niels
