mkl_rt.dll missing
Victor-Gabriel_Marian
Hello.
I need the ifort fortran compiler for MSC Marc 2024 and also the mkl library. So i installed the 2024 OneBase Toolkit with MKL Library. I also installed the 2024 HPC Toolkit. But mkl_rt.dll is missing and it seems I need it.
What should I do?
Please help.
Fengrui
How is the single dynamic library, mkl_rt.dll, used in MSC Marc 2024? Normally if lib\mkl_rt.lib is linked, it will find and load bin\mkl_rt.2.dll, where the number 2 (could be different in different oneMKL versions) is the version of this dll.
Hello.
I found out in the release guide that marc 2024.1 requires OneApi 2023.1. I installed the 2024 version which has not the same paths. However I could not find the 2023.1 version to download. Where can I find it?
Fengrui
Hello!
Older tools are available on demand if you have priority support with Intel, You can request them by opening a ticket and someone will help you with the request
How to get access to our tools & Intel® Developer Tools Priority Support:
  1. Create an Intel® account if you don’t have one
  2. Register your Priority Support Entitlement at the Intel® Registration Center
  3. Submit a support request
    1. For details and help go to How to Submit a Request
