mkl_scscmm performance problem
Ramakrishnan_K_
I am building the attached program in OLCF's RHEA supercomputer (https://www.olcf.ornl.gov/computing-resources/rhea/)  with Intel compiler icc (ICC) 14.0.4 20140805. Armadillo has a naive implementation of cscmm. I run the program with MKL_NUM_THREADS=1 in rhea to multiply the sparse matrix of size 83328x124992 with a dense matrix of size 124992x50. The following is the output.
 ./a.out 83328 124992 50 0.00001
The output of the test code
::A::83328x124992
nnz::104153
::B::124992x50
mkl cscmm::162.13
::C::50x83328
arma ::0.06
I am seeing MKL_CSCMM to be really slow over armadillo naive implementation. Kindly let me know what am I doing wrong here.
Ramki
Gennady_F_Intel
may you check if this gap exists with the latest mkl 11.3.update 3? you may take evaluation package of intel complier v.16.  May you also check CSR ( mkl_dcsrmm  )  case?
