mkl_sparse_?_svd implementation
Robert_E_
is mkl_sparse_?_svd yet implemented and supposed to work?
source:
https://software.intel.com/en-us/onemkl-developer-reference-fortran-mkl-sparse-svd
Because after trying several things I get error 6, SPARSE_STATUS_NOT_SUPPORTED every time.
I'll give you a MWE when it's implemented.
Gennady_F_Intel
hi Robert,
Yes, it should work. You could check the latest version v.2020 or give us the reproducer to check the problem on our side.
Gennady_F_Intel
hi Robert,
Robert_E_
thank you!
I tried more things and it works. The problem was that my matrix was in CSC format. The documentation does not state that only CSR format is supported, or maybe I'm blind.
If you want sugesstions on improving the documentation, read on, else I'm done here. Thanks for the great work and support!
errors in documentation:
The interface should be
stat = mkl_sparse_d_svd (whichS, whichV, pm, A, descrA, k0, k, E, XL, XR, res);
instead of
stat = mkl_sparse_d_svd (whichS, whichV, pm, A, descrA, k0, k, E, X, res);
I think the term "eigenvalues" should be replaced with the term "singular values" everywhere.
Gennady_F_Intel
Thanks, Robert for these issues. We will fix all of these topics.
Gennady_F_Intel
The error into documentation has been fixed into version 2020 u1 which already released and available.
