7299 Discussions
Problems to connect MKL with VISUAL STUDIO 2019
Berni_25
I have two PC on which I installed VISUAL STUDIO 2019. With both PC I try to connect with MKL. At one PC it works, here I installed MKL 2019. At the other PC where it does not work, I installed MKL 2020. But if I remove MKL 2020 and installed MKL 2019 it brings no success.
If I compile at VISUAL Studio I receive the message:
Fehler    MSB3073    Der Befehl "mkl_link_tool.exe -libs -c ms_c -a ia32 -p no 2> NUL" wurde mit dem Code 9009 beendet.    XXX-werk-core    C:\Program Files (x86)\Microsoft Visual Studio\2019\Community\MSBuild\Microsoft\VC\v160\Platforms\Win32\PlatformToolsets\v142\ImportBefore\Intel.Libs.MKL.v142.targets
Has someone an idea?
Thanks a lot,
Berni
Gennady_F_Intel
it seems the issue is caused by fact that mkl_link_tool.exe has been moved from mklroot/tool to mklroot/bin folder. the easiest way to fix the case - copy this exe from bin to tool folders and try to run once again.
Gennady_F_Intel
Have you tried to use this tips?
