7303 Discussions
mkl_verbose_output_file to same output as main code
JeffS
My code generates an output file as many do...  There are a number of MKL calls throughout the code and I want to MKL_VERBOSE output to go to the same output file that my code is writing to.
I tried to implement this by using mkl_verbose_output_file(filePath)
  • If I set filePath to my output file... the return code is 0 (Success), but there is no verbose output in the file.
  • If I set filePath to another file name, return code is 0, and I do get output to the path I set
Can the MKL_VERBOSE output be directed to a file that is shared with the main code?
If everything goes to stdout (program output and MKL_VERBOSE), then I can capture by piping to a file.  However this code is run using MPI master/slave so I cannot just dump to stdout.
Side note:  mkl_verbose_output_file seems to require calling with trim(filePath).  I was getting a return status of 1 until I used trim().  I would expect it to work like open() where it handles trimming inherently.
AryanK_Intel
Could you please kindly clarify if the mentioned output refers to verbose information, the actual code output, or a combination of both?
Thanks and Regards,
Aryan.
JeffS
The output is only the MKL_VERBOSE output.
I want to achieve combined output to a single file.  Without using std out.
AryanK_Intel
We are looking into your issue internally and we will update you soon.
Thanks and Regards,
Aryan
AryanK_Intel
Thanks for sharing your requirement.
This feature is currently not available. We will update this thread once we implement this feature.
Thanks & Regards,
Aryan.
Fengrui
mkl_verbose_output_file doesn't require to call trim() now. This feature has been added in 2025.0 release.
