7301 Discussions
newbi: using mkl examples - i.e. #include "mkl_dfti_examples.h"
Erich_Zwyssig
Hija all
The examples in e.g. /opt/intel/mkl/10.2.2.025/examples/dftc/ use
Where do I find the object (or .c) files to link the examples?
Thanks for your help
Erich
Alexander_K_Intel2
Hi Eric,
Try to find it in directory /examples/dftc/source/
With best regards,
Alexander Kalinkin
Erich_Zwyssig
Hi Alex
Thanks for your reply. I tried to find mkl_dfti_examples.o or .c, but I see that these routines
are in
- dfti_example_status_print.c
- dfti_example_support.c
Would you be able to tell me what the error below means?
g++ -c -Wall -g -I include -I /usr/include -I /opt/intel/mkl/10.2.2.025/examples/dftc/source -I KLINCLUDE -I PPINCLUDE src/mkl_dfti_example.cpp -o mkl_dfti_example.o
src/mkl_dfti_example.cpp: In function int main(int, char**):
src/mkl_dfti_example.cpp:75: warning: format %d expects type int, but argument 2 has type long int
g++ -c -Wall -g -I include -I /usr/include -I /opt/intel/mkl/10.2.2.025/examples/dftc/source -I KLINCLUDE -I PPINCLUDE -c -o dfti_example_status_print.o /opt/intel/mkl/10.2.2.025/examples/dftc/source/dfti_example_status_print.c
g++ -c -Wall -g -I include -I /usr/include -I /opt/intel/mkl/10.2.2.025/examples/dftc/source -I KLINCLUDE -I PPINCLUDE -c -o dfti_example_support.o /opt/intel/mkl/10.2.2.025/examples/dftc/source/dfti_example_support.c
/opt/intel/mkl/10.2.2.025/examples/dftc/source/dfti_example_support.c: In function int init_forward_tone_and_expected_result_c(void*, void*, long int):
/opt/intel/mkl/10.2.2.025/examples/dftc/source/dfti_example_support.c:279: error: invalid conversion from void* to float*
/opt/intel/mkl/10.2.2.025/examples/dftc/source/dfti_example_support.c:280: error: invalid conversion from void* to float*
bon weekend
Erich
mecej4
Do you ask about the location of the example sources, the MKL header files or the MKL library?
Anyway, all these are located in a fairly logical and simply organized set of directories. For example, the libraries on our system are in /opt/intel/mkl101/lib/em64t. the header files in /opt/intel/mkl101/include/ and the example sources are in /opt/intel/mkl101/examples/ .
Unless you have a nonstandard installation, these paths, modified to suit your version of MKL and machine architecture, should work.
barragan_villanueva_
Valued Contributor I
Erich,
It looks like you use incorrectly g++.
In order to run dftc examples please use make in the directory/opt/intel/mkl/10.2.2.025/examples/dftc/
% make help
Usage: make {libia32|soia32|libintel64|sointel64} [function=name]
[compiler=compiler_name] [interface=interface_name] [threading=threading_name]
[omp=omp_name] [parallel=parallel_name]
name - function name. Please see dftc.lst file
compiler_name - can be gnu, pgi or intel. Default value is intel.
Intel C Compiler as default
omp_name - can be iomp5 if parallel=intel or
can be iomp5 or gomp if parallel=gnu or
can be pgmp if parallel=pgi.
Default value is iomp5.
interface_name - can be lp64 or ilp64 for intel64. Default value is lp64.
parallel_name - can be intel (default value), pgi (only if compiler=pgi) or
gnu (if compiler=gnu).
threading_name - can be parallel or sequential. Default value is parallel.
Erich_Zwyssig
Hi Victor
Thank you for your help.
That's compiling now, thanks.
Erich
