7303 Discussions
oneAPI MKL manually linking problem in VS2017
di_luca__daniele1
Hello everybody,
I'm trying to manually linking the new oneAPI MKL in Visual Studio 2017.
What I did is (x64):
c/c++-->general-->Additional include directories
         C:\Program Files (x86)\Intel\oneAPI\mkl\2021.1.1\include
linker-->general-->Additional library directories
         C:\Program Files (x86)\Intel\oneAPI\mkl\2021.1.1\lib\intel64
linker-->input-->additional dependencies
         mkl_intel_lp64.lib
         mkl_intel_thread.lib
         mkl_core.lib
         libiomp5md.lib
I know I'm missing something, as the VS compiler always returns the following error msg: "LNK1104 cannot open file "libiomp5md.lib", but all additional directories I tried to add failed, so please what other directories should I include/link?
Everything works fine by using the automatic linking option, but I need to make it work this way too.
I'm using Visual Studio Community 2017 in Windows 10 (2004).
Thanks in advance.
mecej4
I see 32-bit and 64-bit versions of libiomp5md.lib in
     ...\ONEAPI\compiler\latest\windows\compiler\lib\ia32_win
and
     ...\ONEAPI\compiler\latest\windows\compiler\lib\intel64_win,
but those are directories containing components of the Intel Fortran and C compilers.
The corresponding DLLs are in
     ONEAPI\compiler\latest\windows\redist\ia32_win\compiler
     ONEAPI\compiler\latest\windows\redist\intel64_win\compiler
If you did not install the OneAPI C++ or Fortran compilers, you will probably need to obtain OpenMP libraries (and DLLs?)  from elsewhere, but I have not chosen that route and so I cannot give you specific advice.
mecej4
and
di_luca__daniele1
thank you mecej4,
as you said, it works that way by using the OneApi C++, but it doesn't when I try to compile it by using VisualC++, I wonder where I might find those OpenMP missing files elsewhere..
Gennady_F_Intel
There is one problem we detected recently. The standalone version of MKL doesn't contain libiomp5md.lib library (similar to Linux package as well). It might be a reason when Users couldn't build oneMKL based application with OpenMP threading runtime.
The problem is escalated and we will keep this thread updated when the fix will happen.
As a workaround, the User could take and install oneAPI Base toolkit, install only C/C++ compiler and libiopm5md.lib would be installed on your system.
-Gennady
Gennady_F_Intel
The issue is closing and we will no longer respond to this thread. If you require additional assistance from Intel, please start a new thread. Any further interaction in this thread will be considered community only.
