7298 Discussions
pardiso error with segmentation fault
NEROKAI
I tried to encapsulate PARDISO with a simple wrapper, why doesn't this kind of encapsulation work? Not only in C++, but also in C language, errors occur when using `pt` across functions. This is the minimal unit for reproducing the error. Thank you.
Gennady_F_Intel
I hardcoded your code by allocating the solution array and solution has been passed:
void NumericalAlgebra::solve(double* b, double* result)
  MKL_INT phase=33;
 double* x = (double*)mkl_malloc(N*sizeof(double), 64);
  pardiso(m_pt,&m_maxfct,&m_mnum,&m_type,&phase,&N,values, rowindex,colindex,&idum,&nrhs,m_iparm,&m_msglvl, b, /*result*/ x, &m_error);
  if( m_error != 0 ) {
    printf("... Failure. Pardiso Fails at the Solution ( phase == 33 ) stage. m_error == %lld \n", m_error );
  } else {
    printf("... Passed - Pardiso at the Solution ( phase == 12) stage \n");
here is the log output:
       number of non-zeros in U:        1
       number of non-zeros in L+U:       6
       gflop  for the numerical factorization: 0.000000
       gflop/s for the numerical factorization: 0.000027
Gennady_F_Intel
how do you allocate solution array ( which is double *result into your code)?
Gennady_F_Intel
  MKL_INT phase=33;
  } else {
NEROKAI
Thank you very much. I made a very stupid mistake. I thought pardiso could allocate memory automatically. Thank you!
