pardiso returns error code -1
PhilipS1
Hi there,
I moved from imkl compiled with VS 2015 toolset V140 to oneAPI 2025.0 compiled on VS 2022 toolset V143, all C++, and now get consistently  error code -1 (input inconsistent) using the same matrix-vector systems as before.
Here's a small example taken from pardiso_unsym.c that now goes wrong (just up to symbolic fact phase, that's where things already go wrong => error code -1):
/* Matrix data. */
MKL_INT n = 5;
MKL_INT ia[6] = { 1, 4, 6, 9, 12, 14 };
MKL_INT ja[13] =
{ 1, 2, 4,
1, 2,
3, 4, 5,
1, 3, 4,
2, 5
double a[13] =
{ 1.0,-1.0, -3.0,
-2.0, 5.0,
4.0, 6.0, 4.0,
-4.0, 2.0, 7.0,
8.0, -5.0
MKL_INT mtype = 11; /* Real unsymmetric matrix */
// Descriptor of main sparse matrix properties
struct matrix_descr descrA;
// Structure with sparse matrix stored in CSR format
sparse_matrix_t csrA;
sparse_operation_t transA;
/* RHS and solution vectors. */
double b[5], x[5], bs[5], res, res0;
MKL_INT nrhs = 1; /* Number of right hand sides. */
/* Internal solver memory pointer pt, */
/* 32-bit: int pt[64]; 64-bit: long int pt[64] */
/* or void *pt[64] should be OK on both architectures */
void* pt[64];
/* Pardiso control parameters. */
MKL_INT iparm[64];
MKL_INT maxfct, mnum, phase, error, msglvl;
/* Auxiliary variables. */
MKL_INT i, j;
double ddum; /* Double dummy */
MKL_INT idum; /* Integer dummy. */
/* .. Setup Pardiso control parameters. */
for ( i = 0; i < 64; i++ )
iparm[i] = 0;
iparm[0] = 1; /* No solver default */
iparm[1] = 2; /* Fill-in reordering from METIS */
iparm[2] = 1; //# procs
iparm[3] = 0; /* No iterative-direct algorithm */
iparm[4] = 0; /* No user fill-in reducing permutation */
iparm[5] = 0; /* Write solution into x */
iparm[6] = 0; /* Not in use */
iparm[7] = 2; /* Max numbers of iterative refinement steps */
iparm[8] = 0; /* Not in use */
iparm[9] = 13; /* Perturb the pivot elements with 1E-13 */
iparm[10] = 1; /* Use nonsymmetric permutation and scaling MPS */
iparm[11] = 0; /* Conjugate transposed/transpose solve */
iparm[12] = 1; /* Maximum weighted matching algorithm is switched-on (default for non-symmetric) */
iparm[12] = 0;
iparm[13] = 0; /* Output: Number of perturbed pivots */
iparm[14] = 0; /* Not in use */
iparm[15] = 0; /* Not in use */
iparm[16] = 0; /* Not in use */
iparm[17] = -1; /* Output: Number of nonzeros in the factor LU */
iparm[18] = -1; /* Output: Mflops for LU factorization */
iparm[19] = 0; /* Output: Numbers of CG Iterations */
maxfct = 1; /* Maximum number of numerical factorizations. */
mnum = 1; /* Which factorization to use. */
msglvl = 1; /* Print statistical information */
error = 0; /* Initialize error flag */
/* .. Initialize the internal solver memory pointer. This is only */
/* necessary for the FIRST call of the PARDISO solver. */
pt[i] = 0;
/* .. Reordering and Symbolic Factorization. This step also allocates */
/* all memory that is necessary for the factorization. */
phase = 11;
PARDISO(pt, &maxfct, &mnum, &mtype, &phase,
&n, a, ia, ja, &idum, &nrhs, iparm, &msglvl, &ddum, &ddum, &error);
if ( error != 0 )
printf("\nERROR during symbolic factorization: " IFORMAT, error);
exit(1);
etc.
I tried a 1x1 matrix vector system but with the same result.
Someone any idea?
Thanks!
PhilipS1
Ok, found the solution myself, maybe helping others:
In the installation of oneAPI in step 3 (integrate with IDE) integrate with Visual Studio 2022 and then in the project properties -> Configuration Properties you see "Intel(R) Libraries for oneAPI", where you can select "Use oneMKL", set this to eg parallel.
Then all works fine.
best regards,
Philip
PhilipS1
best regards,
Philip
