7297 Discussions
pardiso with parallel MKL and TBB on large systems
Goldis__John
I'm solving a large sparse system with pardiso. I'm using the Parallel MKL library with TBB enabled on Windows 64bit system. My A matrix is 57k x 57k and my right hand side B matrix is 57k x 45k.
When I run the code, I get an error during the solution = -2. If I switch to using the Sequential version of MKL,  the peak memory used is about 80GB but the process solves. In the parallel mode, I get the output regarding the statistics of the parallel direct factorization and the error happens almost immediately so it doesn't seem like it's actually trying to do the forward/backward substitution.
It seems that pardiso is just trying to use up all available memory in parallel mode. I have tried on machines with 64GB memory, 72GB and 128GB and each time, if I check on the value: max(iparm[14], iparm[15] + iparm[16]) before the solve phase (I'm using C indexing)  the results is always returned as the remaining free memory on the machine.
Gennady_F_Intel
What version of lib do you use?  Is that specific with TBB based threading mode or the same with OpenMP mode too?
Goldis__John
I'm using the Build date: 08 Nov 2017  version.  I tried with and without TBB and am getting the same result. The factorization takes about 20 GB of memory and then i immediately get the error. The machine has 140GB of RAM (it's an AWS c5.18xlarge instance). Here are my solver settings and I've tried with iparm[1] set to both 2 and 3 as well as iparm[24] at both 0 and 1 (although probably missed some combinations with TBB on/off).
iparm[0] = 1;
iparm[1] = 2;
iparm[3] = 0;
iparm[4] = 0;
iparm[5] = 0;
iparm[7] = 2;
iparm[9] = 8;
iparm[10] = 1;
iparm[12] = 0;
iparm[13] = 0;
iparm[17] = -1;
iparm[18] = -1;
iparm[19] = 0;
iparm[20] = 1;
iparm[24] = 1;
iparm[34] = 1;
thanks!
