passing additional parameters to RHS function of ODE solver
Bo_Q_
I am trying to use the Intel's ODE solver to solver a system of equations. Below is the how the RHS function is supposed to be defined (from manual):
subroutine <name>(n, t, y, f)
integer n
double precision t, y(n), f(n)
f(i) = .....
return
end
The problem is I need to pass additional parameters to the RHS function. Is there a way to do that?
Thanks!
Bo
mecej4
Declare the additional parameters and variables in a module. USE that module in the main program, and read/assign values to the module variables as needed. In the subroutine that implements the specific ODE, USE the module and access the variables as needed.
For example, you can modify the van der Pol example that is included with the Intel ODE solver to take a parameter K in place of 1.0d6 in the equation: y” - K * [ ( 1 - y*y ) * y’ + K * y = 0. Then, the module contains:
      MODULE PARS_MOD
         double precision :: K
      END MODULE
Add "USE PARS_MOD" to all subprograms that need to set/get the value of K.
In the main program, you can do:
      WRITE(*,'(A)',advance='no')' Enter K : '
      READ (*,*) K
In subroutine rhs_v_d_p, change to
         f(2)=K*((1.d0-y(1)*y(1))*y(2)-y(1))
and, in subroutine jacmat_v_d_p, change to
         a(2,1)=-K*(1.d0+2.d0*y(1)*y(2))
         a(2,2)= K*(1.d0-y(1)* y(1))
You will probably need to deactivate all the result checks, since they use pre-computed results that are correct only for the specific case K = 1.0d6.
mecej4
      MODULE PARS_MOD
      END MODULE
      READ (*,*) K
