7298 Discussions
?potrf and ?potrs: memory requirement for a coefficient matrix
Frolo
Hello Forums,
If the coefficient matrix A is a large dense but symmetric matrix, how can I handle memory efficiently when solving Ax=b?
I have used dpotrf and dpotrs for an n-by-n double precision real-valued matrix A, but I am wondering whether I should allocate n-by-n array all the time for A. This matrix is symmetric, which means only the upper (or lower) triangular part is necessary, n*(n+1)/2 entries. Does A's memory requirement have to be 8bytes*n*n or can it be lowered? Is there a way or should we reserve n-by-n array for possible fill-ins during factorization?
Any comments would be appreciated.
Best,
Yonghyun
kdv
Hi, Yonghyun!
For dpotrf and dpotrs the only usage is allocation of n x n memory.
Try to use routines dpptrf and dpptrs in special packed format. Dimension of input arrays n * (n - 1) / 2. But performance can be different, than dpotrf and dpotrs have.
Dmitry
kdv
Hi, Yonghyun!
Dmitry
Frolo
Thank you very much.
Your answer is what I am looking for. I will try those routines right now.
If possible, can you tell me more about how the performance might be differ? As soon as possible, I would like to know.
Best,
Yonghyun
kdv
Performance of packed routines could be lower, than dpotrf and dpotrs have since another type of data structure is used. But I don't know actual value since I am not a developer of MKL. Maybe its performance is good enough for you. The fastest way to know it is just to implement a performance test and compare results.
Dmitry
Frolo
Hello Dmitry!
Thank you for your kind reply. Your explanation helped my understanding a lot.
Yonghyun
VidyalathaB_Intel
Hi Yonghyun,
Glad to know that your issue is resolved and thanks for the confirmation.
Please post a new question if you need any additional assistance from Intel as this thread will no longer be monitored.
Vidya.
