problem in DSS_FACTOR_complex
haijunwu
I just modified the test program dss_sym_f90 in examples\\solver\\source
by converting the real data to complex type with real part are zero. the program complies well without error,
but exit at calling DSS_FACTOR_complex. I do not know why?
! INTEL CONFIDENTIAL
! Copyright(C) 2004-2009 Intel Corporation. All Rights Reserved.
! The source code contained or described herein and all documents related to
! the source code ("Material") are owned by Intel Corporation or its suppliers
! or licensors. Title to the Material remains with Intel Corporation or its
! suppliers and licensors. The Material contains trade secrets and proprietary
! and confidential information of Intel or its suppliers and licensors. The
! Material is protected by worldwide copyright and trade secret laws and
! treaty provisions. No part of the Material may be used, copied, reproduced,
! modified, published, uploaded, posted, transmitted, distributed or disclosed
! in any way without Intel's prior express written permission.
! No license under any patent, copyright, trade secret or other intellectual
! property right is granted to or conferred upon you by disclosure or delivery
! of the Materials, either expressly, by implication, inducement, estoppel or
! otherwise. Any license under such intellectual property rights must be
! express and approved by Intel in writing.
! Content : MKL DSS Fortran-90 example
! Example program for solving a symmetric positive definite system of
! equations.
INCLUDE 'mkl_dss.f90' ! Include the standard DSS "header file."
PROGRAM solver_f90_test
use mkl_dss
IMPLICIT NONE
INTEGER, PARAMETER :: dp = KIND(1.0D0)
INTEGER :: error
INTEGER :: i
INTEGER, PARAMETER :: bufLen = 20
! Define the data arrays and the solution and rhs vectors.
INTEGER, ALLOCATABLE :: columns( : )
INTEGER :: nCols
INTEGER :: nNonZeros
INTEGER :: nRhs
INTEGER :: nRows
REAL(KIND=DP), ALLOCATABLE :: rhst( : )
complex(kind=dp),allocatable :: rhs(:)
INTEGER, ALLOCATABLE :: rowIndex( : )
!REAL(KIND=DP), ALLOCATABLE :: solution( : )
!REAL(KIND=DP), ALLOCATABLE :: values( : )
complex(KIND=DP), ALLOCATABLE :: solution( : )
REAL(KIND=DP), ALLOCATABLE :: valuest( : )
complex(KIND=DP), ALLOCATABLE :: values(:)
TYPE(MKL_DSS_HANDLE) :: handle ! Allocate storage for the solver handle.
REAL(KIND=DP),ALLOCATABLE::statOUt( : )
CHARACTER*15 statIn
INTEGER perm(1)
INTEGER buff(bufLen)
complex(kind=dp) ci
! Set the problem to be solved.
ci = (0_DP,1_DP)
nRows = 5
nCols = 5
nNonZeros = 9
nRhs = 1
perm(1) = 0
ALLOCATE( rowIndex( nRows + 1 ) )
rowIndex = (/ 1, 6, 7, 8, 9, 10 /)
ALLOCATE( columns( nNonZeros ) )
columns = (/ 1, 2, 3, 4, 5, 2, 3, 4, 5 /)
ALLOCATE( valuest( nNonZeros ), values(nNonZeros ))
valuest = (/ 9.0_DP, 1.5_DP, 6.0_DP, 0.75_DP, 3.0_DP, 0.5_DP, 12.0_DP, &
& 0.625_DP, 16.0_DP /)
values = valuest*ci
ALLOCATE( rhs( nRows ),rhst(nrows) )
rhst = (/ 1.0_DP, 2.0_DP, 3.0_DP, 4.0_DP, 5.0_DP /)
rhs = rhst*ci
! Initialize the solver.
error = DSS_CREATE( handle, MKL_DSS_DEFAULTS )
IF (error /= MKL_DSS_SUCCESS) GOTO 999
! Define the non-zero structure of the matrix.
error = DSS_DEFINE_STRUCTURE( handle, MKL_DSS_SYMMETRIC_COMPLEX, rowIndex, nRows, &
& nCols, columns, nNonZeros )
! Reorder the matrix.
error = DSS_REORDER( handle, MKL_DSS_DEFAULTS, perm )
! Factor the matrix.
error = DSS_FACTOR_complex( handle, MKL_DSS_DEFAULTS, values )
! Allocate the solution vector and solve the problem.
ALLOCATE( solution( nRows ) )
error = DSS_SOLVE_complex(handle, MKL_DSS_DEFAULTS, rhs, nRhs, solution )
! Print Out the determinant of the matrix (no statistics for a diagonal matrix)
IF( nRows .LT. nNonZeros ) THEN
ALLOCATE(statOut( 5 ) )
statIn = 'determinant'
call mkl_cvt_to_null_terminated_str(buff,bufLen,statIn)
error = DSS_STATISTICS(handle, MKL_DSS_DEFAULTS, buff, statOut )
WRITE(*,"('pow of determinant is '(5F10.3))") ( statOut(1) )
WRITE(*,"('base of determinant is '(5F10.3))") ( statOut(2) )
WRITE(*,"('Determinant is '(5F10.3))") ( (10**statOut(1))*statOut(2) )
END IF
! Deallocate solver storage and various local arrays.
error = DSS_DELETE( handle, MKL_DSS_DEFAULTS )
IF (error /= MKL_DSS_SUCCESS ) GOTO 999
IF ( ALLOCATED( rowIndex) ) DEALLOCATE( rowIndex )
IF ( ALLOCATED( columns ) ) DEALLOCATE( columns )
IF ( ALLOCATED( values ) ) DEALLOCATE( values )
IF ( ALLOCATED( rhs ) ) DEALLOCATE( rhs )
IF ( ALLOCATED( statOut ) ) DEALLOCATE( statOut )
! Print the solution vector, deallocate it and exit
WRITE(*,"('Solution Array: '(5F10.3))") ( solution(i), i = 1, nCols )
IF ( ALLOCATED( solution ) ) DEALLOCATE( solution )
GOTO 1000
! Print an error message and exit
999 WRITE(*,*) "Solver returned error code ", error
STOP 1
1000 CONTINUE
END PROGRAM solver_f90_test
Sergey_Solovev__Inte
Example dss_sym_f90handles withpositive definite matrices. If you convert it into complex test with zero real part, the new matrix becomes indefinite. So, you should factorize matrix as indefinite:
error = DSS_FACTOR_complex( handle, MKL_DSS_INDEFINITE, values )
haijunwu
Thanks it works.
For general complex matrix, if I just can make sure itsdeterminant is not zero, which option should I set toDSS_FACTOR_complex.
