7303 Discussions
problem using mkl with XE2011 composer and visula studio 2008 IDE
morandi__antonio
hi,
I am having problems linking the MKL libraries to my project.
Here is a sample code for matrix inversion
program sample
use mkl95_lapack,only : getrf,getri
implicit none
integer, parameter :: N = 4
integer :: i,j
real(8), dimension(N,N) :: A = (/ 5,7,6,5,7,10,8,7,6,8,10,9,5,7,9,10/)
integer, dimension(N) :: piv
integer :: info
call getrf( a, piv, info )
call getri( a, piv, info )
write(*,10)((a(i,j),j=1,N),i=1,N)
stop
10 format(1x,4F12.6)
end program sample
I tried to link the MKL by following:
Go to Project > Properties > Libraries > Use Intel Math Kernel Library and select Parallel, Sequential, or Cluster as appropriate
but it did not work (unresolved reference external symbols _DGETRF_MKL95 and _DGETRF_MKL95 was obtained as response from the compiler).
what is wrong? Is the code correct?
In general I do not really understand what to "use" or to "include" for correctly linking MKL subroutines (I am quite a beginner user). Could you please hel me with this.
Thank you,
Antonio
mecej4
Your program compiled without errors, so there are probably no errors in your INCLUDE and USE statements.
Add mkl_lapack95.lib (and, if needed, mkl_blas95.lib) to the list of additional libraries to search.
