problem with dgetrf
kon-konstantinov
I have problems calling dgetrf. A small test program is compiled as follows:
/opt/intel/bin/ifort test_intel.f90 -L/opt/intel/composerxe-2011.2.137/mkl/lib/intel64 -I/opt/intel/composerxe-2011.2.137/mkl/include/intel64/ilp64 -lmkl_blas95_ilp64 -lmkl_lapack95_ilp64 -Wl,--start-group /opt/intel/composerxe-2011.2.137/mkl/lib/intel64/libmkl_intel_ilp64.a /opt/intel/composerxe-2011.2.137/mkl/lib/intel64/libmkl_intel_thread.a /opt/intel/composerxe-2011.2.137/mkl/lib/intel64/libmkl_core.a -Wl,--end-group -openmp -lpthread -o test_intel
When I use:
call dgetrf( A, IPIV, INFO )
I get the following:
The matrix has dimensions: n = m = lda = 4
Original matrix A
5.00 7.00 6.00 5.00
7.00 10.00 8.00 7.00
6.00 8.00 10.00 9.00
5.00 7.00 9.00 10.00
forrtl: severe (174): SIGSEGV, segmentation fault occurred
Image PC Routine Line Source
test_intel 0000000000408253 Unknown Unknown Unknown
test_intel 000000000040817C Unknown Unknown Unknown
test_intel 0000000000407DCD Unknown Unknown Unknown
test_intel 000000000040799C Unknown Unknown Unknown
libc.so.6 000000374FA1D994 Unknown Unknown Unknown
test_intel 00000000004078A9 Unknown Unknown Unknown
If I use fortran 77 call:
call dgetrf( m, n, a, lda, ipiv, info )
I get :
MKL ERROR: Parameter 4 was incorrect on entry to DGETRF
parameter INFO is : -4
I would greatly appreciate if somebody can help me to solve my problem. Thanks in advance.
Kon
mecej4
If you want to use the F95 interface with optional arguments, use the generic name GETRF, and USE mkl95_lapack to pick up the interface.
[fortran]program getrfEx
use mkl95_lapack,only : getrf
implicit none
integer, parameter :: N = 4
integer :: i,j
real(8), dimension(N,N) :: A = &
  (/ 5,7,6,5,7,10,8,7,6,8,10,9,5,7,9,10/)
integer, dimension(N) :: piv
integer :: info
call getrf( a, piv, info )
write(*,10)((a(i,j),j=1,N),i=1,N)
stop
10 format(1x,4F12.6)
end program getrfEx
[/fortran]
If you call the F77 routine, you must make sure that your variables are declared with the correct types and contain proper values. Since you showed no declarations or initializations, I cannot say what was wrong.
Gennady_F_Intel
Kon,
please try to relink this example with LP64 not iLP64 libraries and check the problem again.
--Gennady
kon-konstantinov
Here is my code compiled with:
program test_lapack
USE mkl95_LAPACK, ONLY: GETRF
!implicit none
integer :: i, j, k, l, m, n, LDA, INFO, LWORK
real(8), dimension(:,:), allocatable :: A
real(8), dimension(:), allocatable :: WORK
integer, dimension(:), allocatable :: IPIV
n = 4; m = 4
LDA = n
allocate(A(LDA,n), IPIV(n), WORK(n) )
! define lower half of matrix
A(1,1)= 5;
A(2,1)=7; A(2,2)=10
A(3,1)=6; A(3,2)=8; A(3,3)= 10
A(4,1)=5; A(4,2)=7; A(4,3)=9; A(4,4)= 10
! define upper half by symmetry
do i = 1, n
do j = i+1, n
A(i,j)=A(j,i)
end do
end do
print*, " Original matrix A "
do i = 1, n
write(*,fmt='(4f10.2)') A(i,:)
enddo
! call dsytrf( a, ipiv, info )
! call dsytri( a, ipiv, 'L', info )
! call dpotrf( A, 'L', INFO )
! call dpotrf( 'L', n, a, lda, info )
! call dgetrf( m, n, a, lda, ipiv, info )
print*, " parameter INFO is : ", INFO
print*, " LU decomposition using LAPACK DGETRF routine "
!print*, " Cholesky decomposition using LAPACK DPOTRF routine "
do i = 1, n
enddo
LWORK = n
! call dgetri( a, ipiv ,info )
!print*, " parameter INFO is : ", INFO
!print*, " Matrix inverse using DGETRI after LU decomposition using DGETRF routines "
!!print*, " Matrix inverse using DPOTRI after Cholesky decomposition using DPOTRF routines "
!do i = 1, n
!write(*,fmt='(4f10.2)') A(i,:)
!enddo
end program test_lapack
This is the result:
Original matrix A
5.00 7.00 6.00 5.00
libc.so.6 000000368461D994 Unknown Unknown Unknown
kon-konstantinov
Hi Gennady,
Thanks for your reply. I tryed to compile with LP64 instead of iLP64 but I had the same problem. Here is my code:
program test_lapack
!implicit none
n = 4; m = 4
LDA = n
A(1,1)= 5;
A(2,1)=7; A(2,2)=10
do i = 1, n
do j = i+1, n
A(i,j)=A(j,i)
end do
end do
do i = 1, n
enddo
do i = 1, n
enddo
LWORK = n
!do i = 1, n
!enddo
This is the result:
Original matrix A
5.00 7.00 6.00 5.00
test_intel 0000000000408163 Unknown Unknown Unknown
I am stuck, I don't know what to do.
mecej4
The solution was given above, in the first sentence of Response #1.
Konstantin_A_Intel
Hi Kosi,
mecej4 is right, you used f95 interface incorrectly. Correct interfaces are as follows:
FORTRAN 77:
call sgetrf(m,n,a,lda,ipiv,info)
call dgetrf(m,n,a,lda,ipiv,info)
call cgetrf(m,n,a,lda,ipiv,info)
call zgetrf(m,n,a,lda,ipiv,info)
Fortran 95:
call getrf(a[,ipiv][,info])
But in your program you used F77 name (dgetrf) with the arguments of F95 interface. Please use either
call getrf( A, IPIV, INFO )
or
Also make sure you've changed ALL "ilp64" substrings in your compilation link with "lp64". In my program it looked like:
ifort test.f90 -L$MKLROOT/lib/intel64 -I$MKLROOT/include/intel64 -lmkl_blas95_lp64 -lmkl_lapack95_lp64 -Wl,--start-group $MKLROOT/lib/intel64/libmkl_intel_lp64.a $MKLROOT/lib/intel64/libmkl_intel_thread.a $MKLROOT/lib/intel64/libmkl_core.a -Wl,--end-group -openmp -lpthread -o test_intel
bash-4.1$ ./run.sh
Original matrix A
5.00 7.00 6.00 5.00
parameter INFO is : 0
0.86 -0.57 3.14 3.00
0.71 0.25 2.50 4.25
0.71 0.25 -0.20 0.10
kon-konstantinov
Hi Konstantin,
Thank you very much for your help. I followed your instructions and it worked, I got the same answers.
However, my final goal is to inver the matrix. For this purpose I used GETRI subroutine.
I've added to my program:
USE mkl95_LAPACK, ONLY: GETRF, GETRI
call getri( A, IPIV ,INFO )
The result is the same as from GETRF:
Original matrix A
5.00 7.00 6.00 5.00
0.71 0.25 2.50 4.25
Matrix inverse using GETRI after using GETRF routines
0.71 0.25 2.50 4.25
Again I am doing something wrong. Could you help me again please.
One more question. I need a routine that calculates a generalised inverse of non-positive definite matrix.
Do you know such routine from LAPACK. If yes can you tell me how to use it. Thanks very much again.
By the way my first name is also Konstantin.
Cheers,
Kon
mecej4
You probably forgot to CALL GETRI. It is not possible to comment on what could be wrong if you do not show us your code.
Konstantin_A_Intel
In order to get inverse of symmetrical indefinite matrix please use a pair of sytrf/sytri function:
call sytrf( a, uplo, ipiv,info )
call sytri( a, ipiv, uplo, info )
uplo should be either 'U' or 'L' depending on upper or lower part of your matrix is meaninful.
Please refer to online MKL documentation for more details of any functionality.
http://software.intel.com/sites/products/documentation/hpc/mkl/updates/10.3.5/mklman/index.htm
Konstantin
kon-konstantinov
I didn't forget to call GETRI. Here is my code compiled with:
/opt/intel/bin/ifort test_intel.f90 -L/opt/intel/composerxe-2011.2.137/mkl/lib/intel64 -I/opt/intel/composerxe-2011.2.137/mkl/include/intel64/lp64 -lmkl_blas95_ilp64 -lmkl_lapack95_ilp64 -Wl,--start-group /opt/intel/composerxe-2011.2.137/mkl/lib/intel64/libmkl_intel_lp64.a /opt/intel/composerxe-2011.2.137/mkl/lib/intel64/libmkl_intel_thread.a /opt/intel/composerxe-2011.2.137/mkl/lib/intel64/libmkl_core.a -Wl,--end-group -openmp -lpthread -o test_intel
program test_lapack
!Serial number : CZMG-JX2MSWXW
!use deeba
! USE mkl95_PRECISION, ONLY: WP => SP
! USE mkl95_LAPACK, ONLY: GETRI
!implicit none
CHARACTER(LEN=250) :: fin, fout
!PRINT*, ' Enter input file name i : '
!READ(*,*) fin(i)
!PRINT*, ' Enter output file name: '
!READ(*,*) fout
n = 4; m = 4
LDA = n
A(1,1)= 5;
A(2,1)=7; A(2,2)=10
do i = 1, n
do j = i+1, n
A(i,j)=A(j,i)
end do
end do
do i = 1, n
enddo
!print*, " LU decomposition using LAPACK DGETRF routine "
do i = 1, n
enddo
LWORK = n
print*, " Matrix inverse using GETRI after LU decomposition using GETRF routines "
do i = 1, n
enddo
This is the result:
Original matrix A
5.00 7.00 6.00 5.00
0.71 0.25 2.50 4.25
Matrix inverse using DGETRI after using DGETRF routines
0.71 0.25 2.50 4.25
Konstantin_A_Intel
Hi Konstantin,
It seems you're still compiling your code with ilp64 modules that leads to incorrect results. Please replace-lmkl_blas95_ilp64 -lmkl_lapack95_ilp64with-lmkl_blas95_lp64 -lmkl_lapack95_lp64. It should work.
kon-konstantinov
Hi Konstantin,
I've done that and it worked. However, I have another problem. I want to use dgemm from BLAS.
Here is my code:
program test_blas
USE mkl95_BLAS, ONLY: gemm
!implicit none
integer :: i, j, k, l, m, n, lda
real(8), DIMENSION(:,:), ALLOCATABLE :: A, B, C
real(kind=8)::alpha,beta
alpha=1.0;beta=1.0
l
allocate (A(2,3), B(3,2), C(2,2) )
A(1,1) = 1; A(1,2) = 2; A(1,3) = 3
A(2,1) = 4; A(2,2) = 5; A(2,3) = 6
B(1,1) = 2; B(1,2) = 3
B(2,1) = 4; B(2,2) = 5
B(3,1) = 6; B(3,2) = 7
Print*, " Original matriz A : "
do i = 1, 2
write(*,fmt='(13f10.3)') a(i,:)
enddo
Print*, " Original matriz B : "
do i = 1, 3
write(*,fmt='(13f10.3)') b(i,:)
enddo
call dgemm('N', 'N', 2, 2, 3, alfa, a, 2, b, 3, 1.0, c, 2)
print*, " Product matrix C : "
do i = 1, 2
write(*,fmt='(13f10.3)') c(i,:)
enddo
end program test_blas
The result is:
Product matrix C :
0.000 0.000
0.000 0.000
The program is compiled with:
/opt/intel/bin/ifort test_blas.f90 -L/opt/intel/composerxe-2011.2.137/mkl/lib/intel64 -I/opt/intel/composerxe-2011.2.137/mkl/include/intel64/lp64 -lmkl_blas95_lp64 -lmkl_lapack95_lp64 -Wl,--start-group /opt/intel/composerxe-2011.2.137/mkl/lib/intel64/libmkl_intel_lp64.a /opt/intel/composerxe-2011.2.137/mkl/lib/intel64/libmkl_intel_thread.a /opt/intel/composerxe-2011.2.137/mkl/lib/intel64/libmkl_core.a -Wl,--end-group -openmp -lpthread -fast -o test_blas
What is wrong again? Thanks.
Cheers,
Kon
mecej4
Explain why you wrote
call dgemm('N', 'N', 2, 2, 2, alfa, a, 2, b, 2, beta, c, 2)
How is the subroutine to know that matrix a is 2 X 3 and matrix b is 3 X 2, when there is no '3' or variable with value 3 anywhere in the argument list?
kon-konstantinov
OK that was a mistake.
The new call is:
call dgemm('N', 'N', 2, 3, 3, alfa, a, 2, b, 3, beta, c, 2)
and the result is the same. What is wrong?
Konstantin_A_Intel
Please try this one:
call dgemm('N', 'N', 2, 2, 3, alfa, a, 2, b, 3, beta, c, 2)
kon-konstantinov
I've used:
but still getting zero matrix.
mecej4
What is the value of alfa? Why don't you try using IMPLICIT NONE? Or include interfaces for MKL routines:
!DEC$NOFREEFORM
include 'mkl_blas.fi'
!DEC$FREEFORM
