7276 Discussions
problem with linking MKL 10.0.5.025 on ubuntu 8.04
michealniu
I want to develop a program on ubuntu8.04, but when i run ./configure ,the error as follows :
checking for _end in -lmkl_lapack... no
checking for _end in -lmkl_solver... yes
PARDISO sparse solver not available
NO BLAS libraries found - bad for the
the code linking to lmkl_solver is the same as -lmkl_lapack, why?
the configure code~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~
{ echo "$as_me:$LINENO: checking for _end in -lmkl_lapack" >&5
echo $ECHO_N "checking for _end in -lmkl_lapack... $ECHO_C" >&6; }
if test "${ac_cv_lib_mkl_lapack__end+set}" = set; then
echo $ECHO_N "(cached) $ECHO_C" >&6
else
ac_check_lib_save_LIBS=$LIBS
LIBS="-lmkl_lapack $LIBS"
cat >conftest.$ac_ext <<_ACEOF
/* confdefs.h. */
_ACEOF
cat confdefs.h >>conftest.$ac_ext
cat >>conftest.$ac_ext <<_ACEOF
/* end confdefs.h. */
/* Override any GCC internal prototype to avoid an error.
Use char because int might match the return type of a GCC
builtin and then its argument prototype would still apply. */
#ifdef __cplusplus
extern "C"
#endif
char _end ();
int
main ()
return _end ();
return 0;
_ACEOF
rm -f conftest.$ac_objext conftest$ac_exeext
if { (ac_try="$ac_link"
case "(($ac_try" in
*\\"* | *\\`* | *\\\\*) ac_try_echo=\\$ac_try;;
*) ac_try_echo=$ac_try;;
esac
eval "echo \\"\\$as_me:$LINENO: $ac_try_echo\\"") >&5
(eval "$ac_link") 2>conftest.er1
ac_status=$?
grep -v '^ *+' conftest.er1 >conftest.err
rm -f conftest.er1
cat conftest.err >&5
echo "$as_me:$LINENO: \\$? = $ac_status" >&5
(exit $ac_status); } && {
test -z "$ac_cxx_werror_flag" ||
test ! -s conftest.err
} && test -s conftest$ac_exeext &&
$as_test_x conftest$ac_exeext; then
ac_cv_lib_mkl_lapack__end=yes
else
echo "$as_me: failed program was:" >&5
sed 's/^/| /' conftest.$ac_ext >&5
ac_cv_lib_mkl_lapack__end=no
fi
rm -f core conftest.err conftest.$ac_objext conftest_ipa8_conftest.oo \\
conftest$ac_exeext conftest.$ac_ext
LIBS=$ac_check_lib_save_LIBS
fi
{ echo "$as_me:$LINENO: result: $ac_cv_lib_mkl_lapack__end" >&5
echo "${ECHO_T}$ac_cv_lib_mkl_lapack__end" >&6; }
if test $ac_cv_lib_mkl_lapack__end = yes; then
cat >>confdefs.h <<_ACEOF
#define HAVE_LIBMKL_LAPACK 1
_ACEOF
else
mkl_ok=no
fi
{ echo "$as_me:$LINENO: checking for _end in -lmkl_solver" >&5
echo $ECHO_N "checking for _end in -lmkl_solver... $ECHO_C" >&6; }
if test "${ac_cv_lib_mkl_solver__end+set}" = set; then
else
LIBS="-lmkl_solver $LIBS"
/* confdefs.h. */
_ACEOF
#ifdef __cplusplus
extern "C"
#endif
char _end ();
int
main ()
return _end ();
return 0;
_ACEOF
case "(($ac_try" in
esac
ac_status=$?
rm -f conftest.er1
ac_cv_lib_mkl_solver__end=yes
else
ac_cv_lib_mkl_solver__end=no
fi
fi
{ echo "$as_me:$LINENO: result: $ac_cv_lib_mkl_solver__end" >&5
echo "${ECHO_T}$ac_cv_lib_mkl_solver__end" >&6; }
if test $ac_cv_lib_mkl_solver__end = yes; then
mkl_solver_ok=yes
fi
if test $mkl_ok = yes; then
cat >>confdefs.h <<\\_ACEOF
#define HAVE_BLAS 1
michealniu
Thanks forGennady Fedorov's reply,but i could not find your Email.
I download the MKL(non-commercial version) from the follwing link, so i think thelicense for this version is
available,expect from your news~
Todd_R_Intel
I'm not too familiar with configure, and I'm not exactly sure what you're asking with respect to mkl_lapack and mkl_solver. I also don't completely understand your question: "the code linking to lmkl_solver is the same as -lmkl_lapack, why?"
Could you rephrase or expand a little? I'll ask to see if someone here has something to add.
Todd
