Intel64 or em64t
ns2010
I am trying to compile the SPRKKR code using mkl libraries. I installed the non-comercial mkl libraries on my system. It created two folders, "intel64" and "intel32". My OS is 64bit Ubuntu 10.04LTS, so I used library files in the "intel64" folder. By default the progran asks for libraries in the "em64t" folder. The program compiles well, but when I try to run a few examples I am getting errors. The code compiles and run well with "em64t" library but not "intel64".
I dont know the difference between "intel64" and "em64t" library. I tried to download the trial version (not-free) of the mkl libraries, but installing doesnt create "em64t" folder. Can anyone please explain, what is the difference between these two, and how I can get the "em64t" libraries if possible.
NS
Gennady_F_Intel
Hi NS,
intel64 == em64t. ( em64t is the obsolete name).
if you linked correct then it should works.
Please use theLinker Adviserto select the list of libraries you need to use.
--Gennady
