question: mkl_dcsrmv : matdescra
kimjoonshikgmail_com
Would someone help me ?
I need to do matrix-vector multiplication and for that tried to use mkl_dcsrmv( ) functions. My sparse matrix is compressed sparse row format and NOT square matrix. not upper triangular not lower triangular not diagonal. That is just general sparse matrix.
then what 'matdescra' options do I have to use ? for
matdescra[0], matdescra[1], ~ matdescra[3] ?
for matdecra[1], In the manual I can find only 'L', or 'U' options for lower and upper triangular matrix and there are not an option for neither of them.
Thank you.
Joon.
ArturGuzik
Valued Contributor I
Thank you.
Joon.
For general matrix you just put 'G' as first element, then 2nd, and 3rd are ignored anyway, so put anything, and 'F' (for 1-based indexing) or 'C' (for zero-based) as the last one.
See Table Possible Combinations of Element Values of the Parameter matdescra.
A.
ArturGuzik
Thank you.
Joon.
A.
