random numbers with vdrnguniform
Marios_G_
I want to generate random number with the SFMT19937 generator. Everything works fine as long as I store the random numbers to a vector, e.g
      brng=VSL_BRNG_SFMT19937
      method=VSL_RNG_METHOD_UNIFORM_STD
      seed=1777
      errcode=vslnewstream( stream, brng,  seed )
      do j = 1,1000
         errcode=vdrnguniform( method, stream, n, r, lb, ub )
         write(1,*) r(j)
       end do
with this I fill r(1000) with double real random numbers, since the argument r in
vdrnguniform
is a vector.
Is there a way just to generate them without storing them to a vector?
I want to generate several trillions of random numbers for a monte-carlo simulation.
Storing them to an array doesn't seem like a good idea....
Andrey_N_Intel
Hi Marios,
In large scale Monte Carlo simulations that require significant amount of random numbers you generally do not need to store all of them in memory. As Mecej4 mentions above, random numbers can be generated as blocks of the fixed size, and generation of random numbers can be followed by their immediate processing  as shown below
do i = 1,Nexperiments
! size of array n can be aligned with size of (L1) cache of your CPU
errcode=vdrnguniform( method, stream, n, r, 0.0, 1.0 )
! process random numbers
end do
This blocked approach will help you to improve data locality and sets the base for parallelization. On the other hand, we do not recommend to call Intel MKL RNGs on vector size 1 as in this case you would likely to see degradation of your application, please see the chart available at https://software.intel.com/sites/products/documentation/doclib/mkl_sa/111/vsl/functions/uniform_cont.htm. Depending on type of basic random number generator, it makes sense to set the vector size to at least a few hundred elements.
Please, let me know, if it answers your question, or you need more details/clarification.
Andrey
mecej4
There is no requirement that the fourth argument to vdrnguniform, a, be a vector. If you enable interface checking, and you wish to retrieve a single random number with a call to the generator, declare the array as a(1). Alternatively, leave out the USE MKL_VSL statement, to bypass the argument type checking.
You have a great deal of flexibility in whether to generate batches of random numbers into a buffer, to be used and replenished as required, or to generate a single random number with each call.
Marios_G_
If I declare the array as r(1) then the following code:
s=0.0d0
n=20000
 do j = 1, n
               s = s + r(1)
                write(1,*) r(1)
    end do
produces an access violation run-time error. Specifically I get: forrtl: severe (157): Program Exception - access violation
Marios_G_
If I leave out the USE MKL_VSL statement I get compilation warnings:
\Source1.f90(118): warning #6717: This name has not been given an explicit type.   [VSLNEWSTREAM]
\Source1.f90(127): warning #6717: This name has not been given an explicit type.   [VDRNGUNIFORM]
\Source1.f90(139): warning #6717: This name has not been given an explicit type.   [VSLSAVESTREAMF]
\Source1.f90(143): warning #6717: This name has not been given an explicit type.   [VSLDELETESTREAM]
and the code:
              do j = 1, n
               errcode=vdrnguniform( method, stream, n, r1, lb, ub )
               s = s + r1
                write(1,*) r1
              end do
where r1 this time is just a double real variable again produces forrtl: severe (157): Program Exception - access violation at run-time
Andrey_N_Intel
Hi Marios,
end do
Andrey
mecej4
It may help, Marios, to see a short example that illustrates the ideas mentioned in this thread.
The example generates 100 blocks of 100 random numbers each, and computes the mean of the 10,000 random numbers generated.
Marios_G_
Dear Andrey,
thanks for your reply. I solved the problem during the weekend doing the following:
do k = 1, mcsweeps
           errcode=vdrnguniform( method, stream, size, r, lb, ub )
           do j = 1, NY
           do i = 1, NX
               s = s + r((j-1)*NX+i)
                write(1,*) r((j-1)*NX+i)
           end do
           end do
      end do
where r(NX*NY) the size of the lattice. This way I get random numbers for all the lattice sites and all the mcsweeps (which is  Nexperiments in your example) without having to store them in an array of NX*NY*mcsweeps elements.
Actually you suggest the same thing if I understand correctly, right?
Marios
Andrey_N_Intel
Hi Marious,
yes, I suggest the same approach. However, If NX x NY is big enough, say, has order of million(s), it would make sense to make the generation more granular, that is to generate the same amount of numbers NX x NY in chunks of the smaller size and apply processing to each chunk.
While I' not aware about all the details of your application, the loop over k appears to be the candidate for parallelization. Do you consider the option to parallelize that loop using OpenMP or other technology? If so, another BRNG such as MT2203 could be used in this case.
Andrey
Marios_G_
Hi Andrey,
NX*NY is the lattice size so it's not big (less than 100x100). The code above is an example, actually it's more like that:
do k = 1, mcsweeps
	           do j = 1, NY
	           do i = 1, NX
!                   calculate the spin -flip probability U
                      if (r((j-1)*NX+i) < U) S(i,j)=-1.0d0
                      else
                       S(i,j)=1.0d0
	              end if
	           end do
	           end do
	      end do
I am worried about the summation between the candidate spin and it's nearest neighbors in order to parallelize the double loop over NX, NY.
If I manage it do I have to use another RNG? Doesn't each thread just pick an element of r to do it's job? Or each thread/core needs it's own random number sequence?
Thanks again,
Marios
Andrey_N_Intel
Hi Marios,
If iterations of the outer loop over mcsweeps depend on each other in a simple way (for example, say, you need summation of the results obtained for each iteration k), you could do the blocks of iterations in parallel, calculate an save the intermediate results into additional memory, and then  combine them into the final result in the serial part of the function, after the parallel loop is done. Amount of the additional memory is defined by the number of threads used in the code.
To run parallel Monte Carlo simulations you would need one of MKL basic random number generators suitable for goals of your application. RNGs in Intel MKL support parallel simulations via several techniques such as leap-frog, skip-ahead, and a family of BRNGs; each thread would produce  it's own sequence. High level overview of the techniques is available in VSL Training materials at https://software.intel.com/en-us/articles/intel-mkl-vsl-training-material, slides 9-13. Additional details are available in VSL RNG Notes at https://software.intel.com/en-us/mkl_11.1_vslnotes, section "Random Streams and RNGs in parallel computations"; for each basic random number generator the document describes supported parallelization techniques.
Please, let me know, if you need more details.
Andrey
Marios_G_
hello again,
I am trying to use the SFMT19937 RNG in a program that I run in a cluster but I found out that the MKL version the cluster has installed has only the mkl_vsl.f77 version not the f90.
Where can I find documentation on how to generate random numbers using the f77 version of mkl_vsl?
This is really frustrating...
mecej4
Try the following: create a file containing these lines:
      module mkl_vsl
      include 'mkl_vsl.f77'
      end module mkl_vsl
Compile this source file to produce the file mkl_vsl.mod. Then, add "USE mkl_vsl" to your source code from which you wish to callMKL VSL routines.
Whether this suggestion will work will depend on the version of MKL on your cluster.
Marios_G_
I modified the first lines of the code as:
PROGRAM test
 USE IFPORT
IMPLICIT NONE
and it compiled and run correctly on my pc but when I tried it at the cluster I got:
 ifort  -O3 -warn all -xSSE4.2 -parallel -par-report1 -openmp -openmp-report1 -vec-report1 -heap-arrays 0 -mkl -o run.out Long2.F90
/opt/intel/Compiler/11.1/072/mkl/include/mkl_vsl.f77(295): error #6404: This name does not have a type, and must have an explicit type.   [VSL_USER_INIT_DIRECTION_NUMBERS]
      PARAMETER (VSL_USER_INIT_DIRECTION_NUMBERS = 2)
Long2.F90(48): error #6457: This derived type name has not been declared.   [VSL_STREAM_STATE]
 TYPE (VSL_STREAM_STATE) :: stream
Long2.F90(109): error #6404: This name does not have a type, and must have an explicit type.   [VSL_BRNG_SFMT19937]
Long2.F90(110): error #6404: This name does not have a type, and must have an explicit type.   [VSL_RNG_METHOD_UNIFORM_STD]
Long2.F90(151): error #6404: This name does not have a type, and must have an explicit type.   [STREAM]
    errcode=vslnewstream( stream, brng,  seed1 )   ! new stream for the RNG
/opt/intel/Compiler/11.1/072/mkl/include/mkl_vsl.f77(201): remark #7712: This variable has not been used.   [VSL_BRNG_SHIFT]
      INTEGER*4 VSL_BRNG_SHIFT
The good news is that this time the linking to mkl_vsl.f77 is done but,
it seems that  the compiler still doesn't "understand" the mkl_vsl.f77
I still don't understand how it's possible that the cluster's mkl version doesn't have the mkl_vsl.f90. As I see from the first error:
the compiler version is 11.1so how old can the mkl version be?
Any ideas? I am really frustrated with this situation
Marios_G_
hi mecej4,
I also tried your suggestion:
PROGRAM HEATBATH
  USE mkl_vsl
IMPLICIT NONE
I compiled first the file containing the module mkl_vsl
 ifort -c -O3  -parallel -par-report1 -mkl filemod.f90
and then:
ifort ewald.o filemod.o -O3 -warn all -xSSE4.2 -parallel -par-report1 -openmp -openmp-report1 -vec-report1 -heap-arrays 0 -mkl -o run.out Long2.F90
and I got almost the same as in my comment above:
Any ideas?
mecej4
I do not see a definition of VSL_STREAM_STATE in mkl_vsl.f77 under IFort 11.1.070-Windows. Same problem with IFort 2011 SP1 on Windows.
I do see the definition in the version of mkl_vsl.f77 that came with IFort 2013 and later versions.
I think, therefore, that you need to find out the latest version of MKL available on the cluster and write programs that are compatible with that version, unless you can ask the managers of the cluster to update to a more recent version of MKL.
Marios_G_
thanks mecej4,
the cluster uses unix (linux) so I guess the same problem exists there too.
if that's the case where can I find documentation on how to generate properly random numbers using ifort 11.1.070?
mecej4
You will need to ascertain the version of MKL on your cluster. It is probably 10.2 Update 7, but I am not sure -- especially if your cluster uses Itanium CPUs.
You can then search for the MKL documentation on the Intel site, but you may find it hard to locate older documentation. The documentation may be stored on the cluster login nodes or a NFS fileshare. You can also find older manuals at third party sites, such as http://scc.qibebt.cas.cn/docs/compiler/intel/11.1/Intel%20MKL/mklman.pdf .
