7297 Discussions
scipy.linalg.solve CRASH when used with IntelOneAPI 2024.2 MKL on Windows 11
Ashish_Shirodkar
I have raised this issue with scipy :https://github.com/scipy/scipy/issues/21997
Note: ifort was by default selected here for compilation.
           icx and ifx combination gives compilation errors on windows.
Please let me know how to go ahead with this problem.
Numpy 2.1.3 built using following commands:
call "C:\Program Files (x86)\Intel\oneAPI\setvars.bat" intel64
set CC=clang-cl
set CXX=clang-cl
python -m pip install . -Cbuild-dir=build -Csetup-args=-Dallow-noblas=false -Csetup-args=-Dblas-order=mkl -Csetup-args=-Dlapack-order=mkl -Csetup-args=-Dblas=mkl -Csetup-args=-Dlapack=mkl
Scipy 1.13.1 built using following commands:
python -m pip install --no-binary :all: pybind11
python -m pip install --no-binary :all: pythran
set CC=clang-cl
set CXX=clang-cl
python -m pip install . -Csetup-args=-Dblas=mkl -Csetup-args=-Dlapack=mkl
scipy.linalg.solve crashed:
C:\Users\ashish.shirodkar>python
Python 3.12.7 (heads/main:20557ca, Oct 18 2024, 07:43:18) [MSC v.1940 64 bit (AMD64)] on win32
Type "help", "copyright", "credits" or "license" for more information.
>>> from scipy import integrate, optimize, linalg, signal, stats, interpolate
>>> import numpy as np
>>> A = np.array([[3, 1], [1, 2]])
>>> b = np.array([9, 8])
>>> x = linalg.solve(A, b)
Reproducing Code Example
import numpy as np
Error message
It just crashed no output.
Ruqiu_C_Intel
Hi Ashish,
Looks I can't reproduce your issue in my side. I am using oneAPI 2025.0, can you try the newer oneAPI version too?
C:\Program Files (x86)\Intel\oneAPI>python
Python 3.12.3 (tags/v3.12.3:f6650f9, Apr 9 2024, 14:05:25) [MSC v.1938 64 bit (AMD64)] on win32
>>> import numpy as np
>>> x
array([2., 3.])
regards,
ruqiu
