7298 Discussions
sparse_matrix_checker reports MKL_SPARSE_CHECKER_OUT_OF_RANGE for a very simple matrix
miaodi1987
I have a 3x4 matrix
0 1 0 0
0 0 2 0
0 0 0 3
the corresponding CSR format is:
ia= [0,1,2,3]
ja= [1,2,3]
va= [1,2,3]
However, when I check it with sparse_matrix_checker, it says:
*** Input check: i=2, ja[i]=3, neqns=3 are incompatible
Matrix check details: (2, 3, 3)
Matrix check result: MKL_SPARSE_CHECKER_OUT_OF_RANGE
Is there any special request  for MKL's sparse matrix that are not listed in the reference ?
Spencer_P_Intel
The sparse matrix checker is part of the sparse solvers system APIs.  the matrix handle there only has a single dimension size meaning it is assuming that the matrix is square (sparse solvers in pardiso depend on matrix being square even though QR can be rectangular, it is a separate set of algorithms and APIs), so the sparse_matrix_checker assumes your matrix is square.
In your case, you have provided neqns = 3 so it is assuming you have a 3x3 matrix , but you have a rectangular matrix input with a column index which is 3 (base 0) which is out of range, hence the MKL_SPARSE_CHECKER_OUT_OF_RANGE return value.
Spencer
Spencer_P_Intel
Spencer
