7303 Discussions
the problem of eigenvalues&eigenvectors of sparse matrix.
han_N_
If  I just want to get smallest eigenvalues and its' eigenvectorsj(0<=j<=n) from a sparse matrix(n*n),'cause the dimension of matrix is too large to calculate all the eigenvalues&eigenvectors at the same time(memory limited) and the smallest j is meet the need, Which funciton should I use?(Matrix store as CSC or CSR format)
Alexander_K_Intel2
You can use Extended EigenSolver functionality. Just make any estimation on eigenvalues (for example norm of matrix) and set small interval near its boundaries to EE functionality with any estimation on number of eigenvalues. If your estimation of number eigenvalues less than real number functionality return correspondent error, if bigger - functionality provide correct answer.
Alex
Alexander_K_Intel2
Alex
han_N_
Alex
It means that I should try some [min max] interval set until it meet the number of j I want?
Alexander_K_Intel2
Just to verify - you need to find smallest eigenvalue or j-th eigenvalue?
han_N_
Hi
I need to find from smallest to the j-th smallest eigenvalues and the eigenvectors associated with the the  eigenvalues (smallest Top J)
Alexander_K_Intel2
In such case make sense to achieve this interval using inertia functionality from PARDISO. So you have initial searching interval (a, b), set c = (a+b)/2 and set matrix B = A-cE. After call PARDISO reordering and factorization phase and get number of negative pivot. If this number less than j than number of eigenvalue in interval (a,c) less than j and you need to increase c and decrease otherwise. After you got new c and new matrix B and repeat pardiso call...
Alex
han_N_
Alex
Oh I got it, it seems like a good way to approach the j-th value and get the interval.
Thanks again
Alexander_K_Intel2
No problem, you are welcome. If it is not a secret, could you explain your application? What is it name or goal?
han_N_
  • I wanna use spectral clustertng algorithm to divide a graph into some clusters, the algorithm need to get some eigenvalues and eigenvectors in order to dimensionality reduciton.
  • Can MKL just calculate the eigenvalues from sparse matrix? That would be easier to locate the interval.
