undefined reference to mkl_serv_iface_allocate(deallocate)
Alexey_K_
Hallo,
I have very strange problem with mkl libraries.
Compiling the code with following options:
MPIF90=mpif90 -mcmodel=medium -openmp -I$(MKLROOT)/include
FFLAGS = -c -O3 -g
MKL =  $(MKLROOT)/lib/intel64/libmkl_scalapack_ilp64.a -Wl,--start-group $(MKLROOT)/lib/intel64/libmkl_intel_ilp64.a $(MKLROOT)/lib/intel64/libmkl_core.a $(MKLROOT)/lib/intel64/libmkl_intel_thread.a -Wl,--end-group $(MKLROOT)/lib/intel64/libmkl_blacs_intelmpi_ilp64.a -lpthread -lm
and trying to use blacs_get and blacs_initgrid routines in my code, I am getting very strange errors, wich are not described elsewhere:
libmkl_blacs_intelmpi_ilp64.a(blacs_extended.o): In function `MKL_BLACS_Deallocate':
blacs_extended.c:(.text+0x241): undefined reference to `mkl_serv_iface_deallocate'
libmkl_blacs_intelmpi_ilp64.a(blacs_extended.o): In function `MKL_BLACS_ALLOCATE':
blacs_extended.c:(.text+0x265): undefined reference to `mkl_serv_iface_allocate'
I will be very thankfull for any help.
Cheers,
Alexey
Evarist_F_Intel
Hi, Alexey
The problem is in the link-line.
Please include $(MKLROOT)/lib/intel64/libmkl_blacs_intelmpi_ilp64.a in --start-group ... --end-group, i.e.
MKL =  $(MKLROOT)/lib/intel64/libmkl_scalapack_ilp64.a -Wl,--start-group $(MKLROOT)/lib/intel64/libmkl_intel_ilp64.a $(MKLROOT)/lib/intel64/libmkl_core.a $(MKLROOT)/lib/intel64/libmkl_intel_thread.a $(MKLROOT)/lib/intel64/libmkl_blacs_intelmpi_ilp64.a -Wl,--end-group  -lpthread -lm
BTW, do not you forget -i8 (or similar) option in FFLAGS? Since you use ilp64 mode, intergers are expected to be a size of 8 bytes.
And finally, if mpif90 stands for MPI driver over GNU Fortran you probably need to link against libmkl_gf_ilp64.a, rather than libmkl_intel_ilp64.a.
MKL Link Line Adviser can help with linking: https://software.intel.com/en-us/articles/intel-mkl-link-line-advisor (however, it doesn't include blacs lib inside the group, which is incorrect).
Evarist_F_Intel
Hi, Alexey
Alexey_K_
Hallo Evarist,
Thank you very much for your help.
I got the line for the library linking from the Intel MKL Library Link Advisor. I did this again, and get the same result:
 $(MKLROOT)/lib/intel64/libmkl_blas95_ilp64.a $(MKLROOT)/lib/intel64/libmkl_lapack95_ilp64.a $(MKLROOT)/lib/intel64/libmkl_scalapack_ilp64.a -Wl,--start-group $(MKLROOT)/lib/intel64/libmkl_intel_ilp64.a $(MKLROOT)/lib/intel64/libmkl_core.a $(MKLROOT)/lib/intel64/libmkl_intel_thread.a -Wl,--end-group $(MKLROOT)/lib/intel64/libmkl_blacs_intelmpi_ilp64.a -lpthread -lm
It seems that there is a bug in Library Link Advisor which should be fixed.
Cheers,
Alexey
