vslloadstreamf and vslsavestreamf
may_ka
I am wondering whether a random number stream created with vslloadstreamf should continue at the state where the previous stream was dumped via vslsavestreamf? I tried the following
  • create a stream via vslnewstream
  • run a loop of 10 filling a matrix with 11 columns with random numbers, but only columns 1-10
  • save the stream state at round 9 via vslsavestreamf
  • destroy the stream after round 10
  • create a new stream via vslloadstreamf
  • fill the 11 column of the above matrix with random numbers from that stream
My expectation was the entries in column 10 and 11 of the matrix are exactly equal. This was not the case. I understood the phrase "saving the stream state" in the mkl manual such that columns 10 and 11 should be equal. Did I miss-understand the implications of "saving the stream state", or did I do anything wrong?
mecej4
I took the example vslstream2file.f that is included in the MKL distribution, and modified it to fit your description, using a real matrix with 10 rows and 11 columns. I found that columns 10 and 11 were identical.
Perhaps the devil is in the details. Please provide your test code and name the compiler version and options.
may_ka
hi
thanks for looking into this
here is the code:
include "mkl_vsl.f90"
program test
  use, intrinsic :: iso_fortran_env, only: int64, real64
  use mkl_vsl
  use mkl_vsl_type
  implicit none
  type(vsl_stream_state), allocatable :: stream
  integer :: seed=12345, err=0, i, n=10
  real(real64), allocatable :: ran(:,:)
  character(:), allocatable :: file
  file="backup"//achar(0)
  allocate(stream)
  err=vslnewstream(stream,vsl_brng_mcg59,seed)
  allocate(ran(n,6),source=0._real64)
  do i=1,5
    err=vdrnguniform(&
      &method=vsl_rng_method_uniform_std_accurate,&
      &stream=stream,&
      &n=n,&
      &r=ran(:,i),&
      &a=0._real64,&
      &b=1._real64&
    if(err/=0) stop("e_1")
    if(i==4) then
      err=vslsavestreamf(stream,file);if(err/=0) stop("e_2")
    end if
  end do
  do i=1,n
    write(54,"(*(g0:"",""))") ran(i,:)
  end do
  err=vsldeletestream(stream);if(err/=0) stop("e_3")
  deallocate(stream);allocate(stream)
  err=vslloadstreamf(stream,file);if(err/=0) stop("e_4")
  err=vdrnguniform(&
      &stream=stream,&
      &n=n,&
      &r=ran(:,6),&
      &a=0._real64,&
      &b=1._real64&
  if(err/=0) stop("e_5")
  write(*,*) maxval(abs(ran(:,5)-ran(:,6)))
  do i=1,n
    write(55,"(*(g0:"",""))") ran(i,:)
  end do
end program test
values in column 5 and 6 are:
.5473213773260636,.5473213773260636
.2389786232270872,.5604556829432085
.8935433105367024,.8387970600185911E-02
.3583476676634463,.3696792567022830
.5604556829432085,.8048426450699457E-01
.2037354232470519,.2041821355220092
.6115156080720576,.2845506451480754
.8546388208725005,.6017603680188723
.8387970600185911E-02,.6126414139055257
.9922226494797135,.7575543283586325
Compiler and mkl versions were 19.05 and 19.1.1. Operation system is linux.
thanks
mecej4
I built and ran your test program on Windows 10 x64 using (i) IFort 16.0.8, (ii) IFort 19.0.5 , and (iii) IFort 19.1.2.
Between runs, I deleted the .mod, .obj and fort.5n files.
In all three runs, the program printed out " 0.000000000000000E+000" and the fifth and sixth columns of output file fort.55 were identical.
I do not have a Linux system with IFort on it as of now. Perhaps someone else with such a system can repeat the test, as it only takes a minute.
Gennady_F_Intel
I see the different outpupts when the different code path has been applied:
>set MKL_CBWR=SSE2
>1.exe
Intel(R) Math Kernel Library Version 2020.0.2 Product Build 20200624 for Intel(R) 64 architecture applications
>set MKL_CBWR=AVX2
>1.exe
 0.885155339936517
We will investigate the cause of the problem and keep the thread updated.
Gennady_F_Intel
The fix of the problem has been released as a part of oneMKL v.2021.1. Intel MKL 2021 package is now ready for download.
MRajesh_intel
Can you please let us know if your issue has been resolved or not?
Rajesh.
MRajesh_intel
Since we didn't hear back from you, we are closing this thread for now. If you require any additional assistance from Intel, please start a new thread. Any further interaction in this thread will be considered community only.
Have a Good day.
Rajesh
