what is ARR_HDR_SIZE in IPP samples
Sathish_S_
Hello All,
I am implementing the JPEG encoding and everything looks fine. But, I want to know the ARR_HDR_SIZE  in uic samples
#include <stdlib.h>
#include <etxt.h>
#include "uic_new.h"
using namespace UIC;
static const unsigned int ARR_HDR_SIZE = 32;
void* UIC::ArrAlloc   (Ipp32u itemSize, Ipp32u nOfItems)
    void *buff = malloc(itemSize * nOfItems + ARR_HDR_SIZE);
    unsigned int *countOf = (unsigned int*)buff;
    *countOf = nOfItems;
    return ((Etxt_DText)buff) + ARR_HDR_SIZE;
void  UIC::ArrFree    (const void* arr)
    Etxt_DText tmp = (Etxt_DText) arr;
    tmp -= ARR_HDR_SIZE;
    free(tmp);
Ipp32u UIC::ArrCountOf(const void* arr)
    return *((unsigned int *)tmp );
in the above code what is the ARR_HDR_SIZE   and what it represents?.
could you anyone help me.
sathish
Ying_H_Intel
Hi Sathish S.
It seems a IPP issue and here is IPP forum : https://software.intel.com/en-us/forums/intel-integrated-performance-primitives, you may submit the issue there in the future.
The ARR_HDR_SIZE = 32  is  for 32-byte alignment.   almost same as the function ippiMalloc
The function ippiMalloc is declared in the ippi.h file. This function allocates a memory block aligned to a
32-byte boundary for elements of different data types. Every line of the image is aligned in accordance with the
pStepBytes parameter, which is calculated by the ippiMalloc function and returned for further use.
And  It is  for better performance, for example,  https://software.intel.com/en-us/node/503946. ;
Ying
